Will it Fit? Targa top question!
Old Mar 27, 2010 | 12:03 PM
96_vette's Avatar
96_vette
Default Will it Fit? Targa top question!
Can a 84-86 targa top fit on a 96 coupe? I know the mounting hardware will have to be changed, but will the targa top itself fit ,or is
there a slight difference in length or mounting location?
Old Mar 27, 2010 | 12:16 PM
engle1147's Avatar
engle1147
I believe the tops themselves are the same but the mounting hardware and the mounting hardware's location would need to be changed.
Old Mar 27, 2010 | 05:16 PM
samsonb's Avatar
samsonb
I'd just get an 89-96 top as that is the style that came on the car. As all you would have to do is adjust it when you put it on. If you go older, then I believe you also have to replace interior trim along with the windshield brackets.
Plus, I'm sure they redesigned the mounting of the top for a reason. The 89-96 tops are alot easier to find, especially with companies who rebuild the tops.
Old Mar 27, 2010 | 05:46 PM
RJblk85vette's Avatar
RJblk85vette
the trim around the windshield is different also
Old Mar 27, 2010 | 06:55 PM
96_vette's Avatar
96_vette
Thanks!!!
To Will it Fit? Targa top question!
