Suspension help needed - 1995 vette
Old Mar 28, 2010 | 08:44 PM
Bobby O.'s Avatar
Bobby O.
Default Suspension help needed - 1995 vette
Alignment is good; car drives straight. Wheels are balanced. Problem is that when I drive over bumps or go into curves, where there are cuts on the road, my stearing wheel shakes. Tie rods are fine. I took off the front wheel and moved side to side etc... nothing out of the norm. What could this be? Could it be the shocks? I did the bounce test and it did not help either. Please help!
Old Mar 29, 2010 | 08:09 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
How many miles?
Have the shocks been replaced?
What kind of shocks on it?
What suspension do you have?
Here is a thought - the mechanisim that allows the wheel to tilt, is it tight. Try shaking the wheel.
Old Mar 29, 2010 | 10:57 AM
mashinter's Avatar
mashinter
You are describing steering shimmy. Think shopping cart front wheel. I would try reducing caster. The driving force is coming from caster. Power steering cars usually have enough damping in the power gear to avoid the shimmy. Is your steering tight?
Old Mar 29, 2010 | 02:18 PM
Bobby O.'s Avatar
Bobby O.
Car has original 72,000 miles. Original shocks. Automatic. Stock suspension.
Steering is tight.
Old Mar 29, 2010 | 03:53 PM
bagpipedave's Avatar
bagpipedave
Navigator
Default Suspension Help Needed-1995 vette
There is some posibility you have a bad tire. Belted radials will sometimes have a belt misaligned during construction.
Old Mar 29, 2010 | 05:33 PM
aminnich's Avatar
aminnich
Steering is tight.
15 yr old shocks. Think they might be a bit past their prime?
Old Mar 29, 2010 | 06:19 PM
RUU's Avatar
RUU
Is it a constant shake, or more of a clunk? Bad lower ball joints caused my steering to clunk when going into a bumpy turn?
Old Mar 29, 2010 | 09:16 PM
Bobby O.'s Avatar
Bobby O.
NO clunking noise. Just shakes when on bumps or on a curb, where the road is bumpy.
Old Mar 29, 2010 | 09:51 PM
resipsa's Avatar
resipsa
I bought my 95 C4 slightly used in Dec of 1995 from GMAC. The car had been repossessed and had 2300 miles on it. The car came with the base suspension. It did the exact same thing you are describing. I had the tires rebalanced and the suspension alignment checked but neither action made a difference. I finally decided to replace the flacidly valved Bilsteins with Koni sport adjustables (BTW- Bilsteins are typically good shocks but the GM-speced versions for the base C4 suspension are not unless you have them revalved). The Konis cured 95 percent of this problem. If you are really cooking into a turn with my C4 and the inside front wheel hits a bump, it still exhibits a very slight shake in the steering wheel. My '02 Z exhibits no such shake in the steering wheel under similar circumstances. So I think the remaining shake is due to the less than rigid body structure of the C4. After owning it for almost 15 years, I dont even notice it anymore as this behavior is part of the character of the car.
Old Mar 30, 2010 | 01:27 PM
Bobby O.'s Avatar
Bobby O.
So. I will try the shocks route, since they are 15 years old. What do you think ok KYB GAS shocks?
Old Mar 30, 2010 | 01:34 PM
aminnich's Avatar
aminnich
Some like the KYB, I prefer the Bilsteins. Stay away from Monroe.
Old Mar 30, 2010 | 02:02 PM
CAJUN C4's Avatar
CAJUN C4
Bilsteins...you can get yours rebuilt by Bilstein for about $65.00 per. Shock I believe.
Old Mar 30, 2010 | 06:58 PM
car5car's Avatar
car5car
Check suspension according to manual. Don't remove wheel.
If you feel free play you need helper. He will move wheel and you grab suspicious parts, ball joints, tire rods, stabilizer links etc.
Old Mar 30, 2010 | 07:17 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Shock preferences are subjective, like what is the best color for a car. I have the Z51 suspension on my `87 & both my wife & I thought the car rode like a brick. I chucked the Bilstiens at 38,000mi & installed Gabriel gas shocks from AutoZone at a cost of around $24.00ea. That was four years ago & the car handles fine & has a better ride IMHO. To each his/her own though
Old Mar 30, 2010 | 08:03 PM
resipsa's Avatar
resipsa
Revalving the Bilsteins is a good option (Doug Rippie Motorsport offers this service). I went with the Koni Sport shocks because they are adjustable. I have the fronts set half way to full hard and the rears set to full soft. The car rides nicely and the front end doesn't move around so much, (the OEM Bilsteins allowed the front end of my car to wallow like an old luxo-boat). Plus, as the shocks wear with mileage, you can adjust them firmer to retain control.
Old Mar 31, 2010 | 11:00 AM
Bobby O.'s Avatar
Bobby O.
Thank you all for your input. I will let you know what happens after I replace the shocks.
To Suspension help needed - 1995 vette
