95 LT1 hard to start
Old Mar 29, 2010 | 10:49 AM
Wicked Ride's Avatar
Wicked Ride
Cruising
Default 95 LT1 hard to start
My 95 turns over very slowly to start, battery is fully charged, will start
eventually. Even harder to start when warm. where should I start.
Old Mar 29, 2010 | 11:06 AM
RRT vette's Avatar
RRT vette
I'd test the battery voltage while cranking to see if it drops. Then check the contacts and connnections at the starter.
Supply more information for the best answers. Does it run good once you get it started?
Old Mar 29, 2010 | 06:55 PM
Wicked Ride
Cruising
Yes, It runs great after it starts.
Old Mar 29, 2010 | 07:42 PM
The Green Rocket's Avatar
The Green Rocket
Okay, it runs great once started - you still need to check the battery voltage while cranking. A battery can have a full charge, but not have much cranking power. Often, when a battery is near the end of its useful life it will give the symptom of slow cranking. When any of my cars has a battery that is 4 or 5 or more years old and it starts cranking slowly - I replace the battery. A good shop will load test the battery. !2 volts by itself is not enough if the cranking amps are low - you need both for good starting performance.
Thomas
Old Mar 29, 2010 | 08:22 PM
Wicked Ride
Cruising
Thanks for the info. will have it cked out.
Old Mar 29, 2010 | 10:20 PM
The Green Rocket
How old is your battery? Alternatively what is the date code on the battery?
Thomas
Old Mar 30, 2010 | 08:12 AM
pcolt94's Avatar
pcolt94
If you have done everything as stated above and the battery is good, then you might just have a tired starter that needs replacement.
To 95 LT1 hard to start
