Putting the engine back into the car - question
Old Apr 2, 2010 | 02:43 PM
Sliding's Avatar
Sliding
Default Putting the engine back into the car - question
I've pulled the engine together with the tranny and I plan to put it back
in the same, but the engine wasn't complete when I pulled it.
So my question is:
Is it possible tu put the engine back in with long tube headres allready
installed or should I put headers later?
Old Apr 2, 2010 | 04:18 PM
Pwnage1337's Avatar
Pwnage1337
I would do the engine first with the headers off. Wouldn't wanna damage them in any way, especially if you have EM or TPIS headers
Old Apr 2, 2010 | 07:08 PM
383vett's Avatar
383vett
I've always installed the engine and then the headers. My setup on an 84 will not go in or out as a complete unit.
Old Apr 2, 2010 | 09:21 PM
aboatguy's Avatar
aboatguy
So my question is:
I know for a fact that my 95 LT1 will go in with EM LT headers attached... I don't know whether it will fit with headers and tranny attached and I don't know a darn thing about an L98
Old Apr 2, 2010 | 10:15 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Another option might be to install just one header. That would give at bit more side-to-side leeway while dropping it in.
How about installing the headers finger tight then seeing if it'll fit. If it does, mount it and tighten the header bolts. If not, pull it up and take the headers off.
Old Apr 3, 2010 | 04:48 AM
Sliding's Avatar
Sliding
That's the right idea!
Old Apr 3, 2010 | 06:23 AM
Fubar569's Avatar
Fubar569
if i can slide my 427 BBC and trans in attached as one piece i don't see why not...
then again i did have block huggers for headers...lol
Old Apr 3, 2010 | 07:14 AM
LD85's Avatar
LD85
I have done it every way imaginable, but once the engine is in, then I put the headers on, because my hooker headers interfere with the motor mount bolt access
Also, it gives me a chance to look around for wiring clearance issues etc.
Old Apr 3, 2010 | 11:59 PM
96z51's Avatar
96z51
the headers can easily be installed from underneath.
Old Apr 4, 2010 | 01:36 AM
ninetyfivevette's Avatar
ninetyfivevette
Probably depends if your are installing the engine solo or with a helper. I tried installing the engine with headers by myself and it was too difficult.
To Putting the engine back into the car - question
