redline
Old Apr 3, 2010 | 09:23 AM
misscoman's Avatar
misscoman
Default redline
does red line water wetter help any to keep water temp. under control.
Old Apr 3, 2010 | 09:45 AM
bacord's Avatar
bacord
I flushed coolant and put in 50/50 water, anti freese and 1 bottle of water wetter and runs about 5-10 degs cooler not sure if it was new coolant or the wetter becouse I did both at same time on my 95 lt1
Old Apr 3, 2010 | 11:49 AM
redrose's Avatar
redrose
Default yes, but
most 'antifreeze' mixes sold today as 'summer/winter' include a 'surfactant' that improves heat transfer by reducing surface tension, check the label on the jug...but racing bodies often prohibit antifreeze in the cooling system because it makes the track slippery and is very difficult to remove after wrecks/engine failures, and in those circs a surfactant additive of some type may increase cooling system op...there are myriads of different chemicals that work as a surfactant when mixed with water, and (of course) the 'special' labeled little cans.
Old Apr 3, 2010 | 11:50 AM
SunCr's Avatar
SunCr
If there's a cooling problem, it won't fix it. Basically, a car should be at or near the thermostat at cruise. Around town, temp should rise to the threshold for fan operation and when the fan(s) come on, the temp should drop. It wasn't designed to get hotter. If yours doesn't do any of this, something needs to be repaired.
Old Apr 3, 2010 | 11:54 AM
desertmike1's Avatar
desertmike1
good info
Old Apr 3, 2010 | 11:59 AM
cv67's Avatar
cv67
St. Jude Donor '05
Never did me any good.
Old Apr 3, 2010 | 01:43 PM
misscoman's Avatar
misscoman
thanks for the info
To redline
