Possible Bose Speaker Amp relay problem?
Old Apr 3, 2010 | 10:10 AM
tazdpc's Avatar
tazdpc
Default Possible Bose Speaker Amp relay problem?
I have a 89 corvette. Last winter I took out the whole dash area to work on the HVAC system. When I put the car back together I found out the Bose speakers were not working. I bought a new speaker amp relay from Corvette Central. When I received it, there was a lot of what looked like dried grease covering the electrical connectors. I installed the relay and the speakers started to work. Then this spring when I would dive the car, the radio would work but when I would turn the engine off and then the radio, the speakers would still make a humming sound. Then when the door would be opened, the security light on the teltale info center would flash and the speakers would make a clicking sound the same time the light would flash. When the ignition was put in the off position, the speakers would not make any more sounds. Any ideas or suggestions?
Old Aug 2, 2011 | 09:46 AM
tazdpc's Avatar
tazdpc
I eventually put the old speaker amp relay back into the car and it is working fine now. When the battery went dead one day and when I charged the battery and hooked it up and started to hear a crackling sound from behind the I/P I decided to try the old relay and it worked again. Was it the cold environment that caused it to not work. Also I have an alternative method of replacing this relay instead of taking out the DIC and working in that tight space.
