Adhesive Needed
Old Apr 4, 2010 | 07:52 AM
dsmithh's Avatar
dsmithh
Default Adhesive Needed
After rebuilding the gear/bushing assembly on my 88's headlight <thanks to this group is was a breeze>, I accidentally popped off the fiberglass cover to the headlight assembly <the colored piece you see when the headlight is down>. It was previously attached with some sort of adhesive. I wonder if Liquid Nails would be appropriate to use, or if I should find something more automotive?
Old Apr 4, 2010 | 11:10 AM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
3 years ago I used RTV Silicone. About 10k miles now still tight.
