when people talk about removing the aluminum or rubber shims on the front spring do they mean the ones towards the center of the spring or the ones that the spring rests on in the a-arm area?? :rolleyes:
I would ask Tim his login name is I_HATE_Mustangs...his vette sits very low and he knows how to drop cars....as a matter of fact every car i have ever seen him own was lowered??? :lol:
You shorten (remove) the rubber pads in the middle part, and the aluminum spacers to compensate. New wedges go against the frame rail between the spring and rails.
however the front doesn't look any lower than it was before you started. :confused:
I made the mistake of putting in the Mid America lowering blocks. It made it 1/2" lower than stock which wasn't good enough for me so I went back in and removed it. Look at this picture:
