bearing/hub question
Old Apr 4, 2010 | 09:28 PM
MP6's Avatar
MP6
Default bearing/hub question
i couldnt find any teflon washers on the assembly and the axle nuts came off with the weight of the breaker bar!
where are the teflon washers located and how many should i buy?
also if i heated the t55 bolts should i replace them?
this is for the rear.
Old Apr 4, 2010 | 10:34 PM
aminnich's Avatar
aminnich
One teflon washer each side, located on spline just inboard of the hub. T55 bolts should be OK.
Old Apr 4, 2010 | 11:46 PM
MP6's Avatar
MP6
thanks
Old Apr 5, 2010 | 07:02 AM
Weav's Vet's Avatar
Weav's Vet
You'll probably have to get those from a dealer.
Old Apr 5, 2010 | 07:33 AM
floridamale's Avatar
floridamale
Dealer only cost about $ 8.00 each
This is a good thread for information
http://forums.corvetteforum.com/c4-t...e-washers.html
Old Apr 5, 2010 | 11:52 AM
StealthLT4's Avatar
StealthLT4
Also, the washers can be installed incorrectly (they are curved in one direction), so just use common sense and make sure they seat on the spline correctly.
Old Apr 5, 2010 | 01:23 PM
l1sikes's Avatar
l1sikes
All of the inner washers that I have purchased from GM are iron oxide coated, not teflon.
Why would teflon coating be required? The washers are firmly clamped between the inner bearing sleeve and the raised step on the spindle. There is no movement between the two.
GM lists them as "seals" not "washers". Their function is to seal the gap between the spindle and the outer sleeve of the bearing.
Old Apr 5, 2010 | 05:46 PM
floridamale
If you look at the link I posted the last frame right out of the FSM they are refered to as washers.
To bearing/hub question
