Don't have specs in front of me but isn't that pretty close to the good ole' GM HOT CAM?
I think they are similar but from what I can tell it might have a little more low end grunt....wanted to know if anyone had a better feel for it than I. I have heard its a pretty good cam tho.
Jake, that is what I have heard too. I think I will go with this instead of hot cam.
LT4 "hot" cam in an LT4 with stock 1.6 ratio rockers = .525 inch lift at the valve which coincidentally is the max recommended lift for stock LT4 valve springs;
better plan on valve spring and retainer upgrades too. Possible new valve seals. May have to modify valve guide height to accommodate the extra lift and eliminate potential valve seal / retainer interference.
If passing smog tests is an issue, investigate that also.
The price is actually very good. That includes retrofit roller lifters. Those things are pricey.
I have never been good and "estimating" what a cam will do by the numbers!
Ah I see, the GM HC actually has a little more exhaust duration and a little more aggressive lobe separation. How lopey do you want the cam to be? I've got a pretty aggressive set up in my car but it's not a daily driver . . . but ohhhhhh I love the sound of a lopey cam.
