Who can recognize this engine sound?
Old Apr 5, 2010 | 08:16 PM
car5car's Avatar
car5car
Default Who can recognize this engine sound?
Sound comes from right rear cylinder area
5 sec
http://www.youtube.com/watch?v=8U-NLNMTvJ8
9 sec
http://www.youtube.com/watch?v=G_cWXLqiQjw
28 second. Walking around to locate sound.
http://www.youtube.com/watch?v=_3Xsv2Qc4U8
Old Apr 5, 2010 | 08:35 PM
lushdrunk's Avatar
lushdrunk
You talking about the under watter sound? I cant tell if it is just the video or not.
Sounds like open compression to me, Check your spark plugs. One maybe loose and letting compression blow by.
The liquid splatter on the back of each valve cover is that related to you prob?
Also remove the oil fill cap with it running, if it has jumped time, or burnt a valve compression will blow by into the valve cover. You will be able to fell an extreme amount of pressure as you put you have over the oil cap hole.
Other then that I can't hear enough from a video.
Old Apr 5, 2010 | 09:01 PM
Calderone's Avatar
Calderone
What's the noise you are referring to ?
1 - compression noise...i can feel something like that
or are you talking about the high pitch pee pee pee ?
Old Apr 5, 2010 | 09:48 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
High pitch pee pee, that sounds like a bladder problem.
Old Apr 5, 2010 | 11:03 PM
mtwoolford's Avatar
mtwoolford
do the easiest stuff first; pull valve cover, look for something adrift in valve train.
Old Apr 6, 2010 | 12:08 AM
car5car's Avatar
car5car
On longest video I begun shooting from left side, there was pretty quet sound. Sound got louder when I moved to rear of right side.
I was listening with stethoscope with stick touching engine and didn't hear anything. I removed stick listening w/o touching engine and located sound near right rear cylinder.
25th second of longest video has loudest sound. Note that camera moved closer to right rear cylinder. Engine is slightly shaking like it has vacuum leak or one cylinder doesn't fire.
On shortest video sound gets louder when camera moves closer.
Old Apr 6, 2010 | 12:18 AM
car5car's Avatar
car5car
I just washed engine.
thanks, guys, I'll check everything tomorrow.
Old Apr 6, 2010 | 01:47 AM
lushdrunk's Avatar
lushdrunk
Did the sound start after you washed the motor? Is your SES light on?
And could you describe the sound to us. I hear something that sounds like a air compressor pump, and I agree with Calderone about the ping sound.
Old Apr 6, 2010 | 06:44 AM
car5car's Avatar
car5car
Sound was before washing, engine light is not on. I would suspect piston sound because it disappears when engine warms up. I was also thinking about air pump sound. When I was buying this car I heard sound and decided it was not engine noise. It is low frequency sound like piston slapping but I cannot hear it with stethoscope stick touching engine, sound is outside of engine.
I just need to listen better.
Old Apr 6, 2010 | 12:22 PM
engle1147's Avatar
engle1147
Sounds like a funky smog pump thump. Remove the "S" belt and start the engine for a few seconds and see if the noise goes away.
Old Apr 7, 2010 | 12:27 PM
car5car's Avatar
car5car
Located to spark plug or exhaust right next to it.
Old Apr 7, 2010 | 01:00 PM
LD85's Avatar
LD85
i hear piston slap, that hollow knock
also, take your serpentine off and start the car for a short time and see if it is accessory
Old Apr 7, 2010 | 01:13 PM
dirtcheap74's Avatar
dirtcheap74
Mine makes that same whup whup whup noise, only when its cold, only on the passenger side. I pulled the valve covers and torqed down the roller rockers to FSM specs, noise still there. My 2000 chevy truck , with a 327 made a very similar noise on the passenger side as well, a little higher pitched.
Old Apr 7, 2010 | 02:38 PM
car5car's Avatar
car5car
I asked best GM mechanic to listen. Hopefully, he'll do it tonight. I'll let you know.
Old Apr 8, 2010 | 05:22 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Valve guide
Old Apr 9, 2010 | 03:11 AM
FOXX's Avatar
FOXX
Almost sounds like mine. GM mechanic told me it was an alternator pully/bearing.
Old Apr 9, 2010 | 08:24 AM
car5car's Avatar
car5car
Originally Posted by LD85
i hear piston slap,
that is what I am worrying about.
To Who can recognize this engine sound?
Old Apr 9, 2010 | 08:01 PM
dirtcheap74
What would would cause piston slap? This would be the 4th chevy motor I have heard that noise on.....the truck I had made it to 130k miles with that noise btw.
Old Apr 9, 2010 | 08:06 PM
Calderone's Avatar
Calderone
i discarded all the accesories and pulleys by starting the engine with no belt, that noise,squeak was gone when i adjusted valves so i thought it was pushrods against the guideplates,it was terrible,so ..i ended up swapping heads which leaded me to a cam intake roller rockers headers swap as well ....LOL
Old Apr 13, 2010 | 03:27 PM
car5car's Avatar
car5car
Exhaust manifold had 2 cracks in it. Welder is charging me $30 for cracks+ 5-10 for attaching shield. Additional minor sound was bad idler pulley.
