OBD1 to usb software
Old Apr 6, 2010 | 08:36 PM
C4 Monster's Avatar
C4 Monster
Default OBD1 to usb software
Any one know of some software I could use with my OBD1 to usb cable so I could see the diagnostics and live readings on my computer, its a 1989 5.7 liter 350 sbc (TPI). THANKS!!
Old Apr 6, 2010 | 08:55 PM
surfer92's Avatar
surfer92
TTS Datamaster, you get 20 uses before you have to buy.
Old Apr 6, 2010 | 08:58 PM
Ning_85_vette's Avatar
Ning_85_vette
Try this site ... http://www.obd2allinone.com/sc/pages.asp?pageid=60 ... has links to many programs that are freeware or try before you buy stuff. Also you might need USB drivers if you did not get them with your cable.
Old Apr 6, 2010 | 09:29 PM
C4 Monster's Avatar
C4 Monster
Thanks I'll give her a shot, you think you could walk me through it? I just bought a odb1 to usb cable, I assume one goes to the vette and the othe to the usb port, once I hook it up do I turn the car on then start the programe or do I need to set some settings first, if so let me know, Thanks
Old Apr 6, 2010 | 09:35 PM
C4 Monster's Avatar
C4 Monster
also wanted to make sure I bought the right cable:
http://www.amazon.com/ALDL-OBD1-Cabl.../dp/B001NQGLIA
and it also said something about a 10k resistor. Does it go somewere in the cable, if so, were? Thanks
Old Apr 6, 2010 | 09:46 PM
surfer92's Avatar
surfer92
Looks like the right cable, did they give you a driver?
If you use Datamaster, you need to download the 92-93 y-body version. Next you need to read their instructions carefully, some people can use the base settings fine and people like me have to tweak them.
Make sure you take the jumper off, that is for earlier ECM's.
Old Apr 6, 2010 | 10:00 PM
JackDidley's Avatar
JackDidley
Datamaster rocks. Its worth buying.
Old Apr 6, 2010 | 10:19 PM
C4 Monster's Avatar
C4 Monster
Cool, I dont know about the driver, its still comming in the mail. I just wanted to make sure, im using the 92-93 y-body for my 1989 tpi corvette. also is it fairly straight forward? You said read the instructions closely so I assume I will be able to find a set of instructions out there either way. Thanks for your help, really appreciate it!
Old Apr 6, 2010 | 10:23 PM
surfer92's Avatar
surfer92
why you don't do 2 things at once.
No use the 89 version, sorry man.
If you don't get a driver, IM me and I will dig up mine and email it to you.
Old Apr 6, 2010 | 10:26 PM
rodj's Avatar
rodj
Originally Posted by C4 Monster
I dont know about the driver, its still coming in the mail.
Most of the USB to serial drivers ( FTDI is the most common) require some " tweaking " of the laptop ports settings.Nothing major , just won't auto detect like with a regular USB device
You have to check what Comms port the laptop has nominated for the cable and then go into the software and select the same port so cable can communicate
How to
http://www.akmcables.com/usb.htm
Old Apr 6, 2010 | 11:16 PM
powerpigz-51's Avatar
powerpigz-51
I am thinking of getting this cable....you just need a driver, not an adapter like the Moates cable, right? I have the 870 ECM (85)
Old Apr 6, 2010 | 11:19 PM
jimg's'93's Avatar
jimg's'93
I'd go with the serial cable over the USB. From all I've read, it's more reliable and an easier start-up.
Old Apr 6, 2010 | 11:23 PM
powerpigz-51
I think most peeps don't have a serial port on their laptops....at least I don't. If I did, I would make a cable.
Old Apr 6, 2010 | 11:33 PM
jimg's'93's Avatar
jimg's'93
I bought a used Dell D400 to be used in the shop. It's small and under $200. It works great for the task
Old Apr 7, 2010 | 01:41 AM
rodj's Avatar
rodj
You still need a cable to physically connect the laptop to the ECM ALDL connector
Cheapest going here
http://www.aldlcable.com/
The driver is only a software program to make the USB port work like a old style serial port that the ECM uses for communication
Once I setup the Comms port correctly,I have never had a problem and because it is powered from the USB port you don't need extra power from the cig lighter
Old Apr 7, 2010 | 01:46 AM
rodj's Avatar
rodj
How is your soldering?
http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
Old Apr 7, 2010 | 01:52 AM
powerpigz-51
So what is that adapter on the Moates set up? Does that take the place of the driver software? And Moates only lists there set up for 86 on up...I'm wondering why that is...
To OBD1 to usb software
Old Apr 7, 2010 | 02:37 AM
ndanl's Avatar
ndanl
true even I paid for it ... and also bought this cable http://www.aldlcable.com/sc/details.asp?item=aldlobd1u which under windows 7 dont even have to worry for drivers
it will detect it automaticaly, for my '91 i just had to make some modification on the port configuration, its documented in the datamaster help
Old Apr 7, 2010 | 02:51 AM
powerpigz-51
Originally Posted by rodj
Thats awesome and I would love to make that....but I have a USB port
Old Apr 7, 2010 | 03:13 AM
rodj's Avatar
rodj
Got a Moates link or part #?
