Does anyone have the front spoiler with the brake cooling ducts?
If so what do you thank about it and where did you run the hose?
Pics?
I just got mine and will be instaling it this weekend.
I have this set up on my 86. If you are tracking the car, it definitely helps. It has greatly reduced brake fade. I ended up wire tying the tubes to the sway bar and aiming them at the rotors.
The duct needs to be much closer to the rotor, the center part. The plastic hose melts but just pull it to extend it out again. Every event mine melts and gets stretched back. I really need to replace it, it lasted good though.
I have them on my car and like them a lot. However I also have the Quantum Motorsports Spindle Ducts that put the air right into the rotor. There is one issue with my set up, the Mid America ducts are 2" hose and the Quantum Spindle Ducts are set up for 3". The way I made it work was the 2" hose fits inside rather than out side the duct inlet.
Unless the hose is right up to the rotor it is a wasted effort.
If you are planning on driving the car to the point where you actually need cooling (track), spindle ducts and high temp ducting with a smooth inner wall (for better flow) is the best choice. If you don't want to spend the extra $ Aardwolf and grantar2 are right on... get that hose right up against the center part of the rotors. The best cooling is from air going THROUGH the rotor vanes, air that is just blowing on the rotor face isn't doing much at all. Best case you are only cooling the inner rotor surface while the outer is getting nothing.
I tested rippled hose verses smooth hose with my turbo car and didn't find any flow difference.
That's interesting... how were you testing and with what speed air? Was the difference negligible or none at all? It seems like pretty simple aero principles that air flows better over a smooth surface than one with a bunch of perpendicular edges.
I believe the simple aero principle of it is that air fills in the lows making it appear smooth. I and others did some tests on inter-cooler tubing at the track on our turbo cars. We didn't find any gains!
dogfish246 you can do the math easy for hose diameter for CFM.
I agree that is that would happen in tubing like that... if that is indeed true, what it means is that the effective inner diameter of the tubing is measured to the highs and the volume of the ridges is lost. If you had a 3" diameter tube with 1/4" ridges it would flow the same amount of air as a 2.5" tube (subtract the 1/4 from both sides). You probably wouldn't see any measurable difference unless you get to the point where the smaller diameter is restricting the flow.
Yes, thats easy, but does the air actually flow through the holes, and to the brakes? Maybe there will be a high pressure buildup at the inlet and cause minimal air flow to the brakes... I dont know, just wondering. Im probably thinking into it too much...
