Crossfire....
Old Apr 10, 2010 | 04:18 AM
Fubar569's Avatar
Fubar569
just a FYI...a big block in these cars is NOT FUN TO DO!
not that i would know or anything...
Old Apr 10, 2010 | 04:19 AM
85vette-84vette's Avatar
85vette-84vette
Originally Posted by qws
Like Kangi says a carb is not a upgrade. In many cases mechanics YES mechanics recommend the carb mainly because they don't fully understand the crossfire. Its not rocket science and is very easy.
You have a restricted intake with 2 throttle bodies and a couple of injectors. Add in a few common sensors and thats all there really is to it. Like stated before its very reliable as well.
Anyways if you do a Bigblock you may have to beef up the front suspension to hold the extra weight. Headers would be a pita to put on. Best way to go small block IMO. Just to give you a idea. Basic common known mods are a set of Dart ss heads ($625 pr), 2040 cam ($140), 1.6rr's ($185), Hedmen headers ($150), 2500 stall ($200 and up). True dual exhaust ($250). Not all mods have to be done at one given time. You start with the free ones Ported intake, cold air mod. For little money you'll have a fun car. All this and you stick with a more modern version of fuel injection rather than a carb. Don't worry about having to "tune" with the 84, leave the ecm alone you can't do much with it anyways. You can get by if you do need to "tune" just by adjusting FP up or advance the timing. Once again both free to do.
84 is a fun car to learn on..... thats what I've done...
Good advice, the cold air mod? What thickness of foam do you use and what is the easiest way to figuire out where to cut the hole so it lines up with hole in the hood? I think I will do this mod while I wait for my renegade intake manifold.
Old Apr 10, 2010 | 06:19 AM
sk8rferlife's Avatar
sk8rferlife
Originally Posted by The Green Rocket
For those wanting to set Tim down the right path (fuel injected small block), just remember that you are dealing with teenage logic (no disrespect meant).
So, the very best thing you can do is to encourage Tim along on the mechanical adventure and let him learn along the way. I see two possible outcomes no matter the initial plans: 1) he surprises all of us with a beautiful big block installation (maybe except for the big hole in the hood and the high rise intake/carb setup protruding another 5" or 6"), or 2) Tim gets part of the way into an unsatisfactory big block conversion before he shifts gears towards a fuel injected small block.
What I am convinced of is that Tim will follow it through to completion. He has already proven himself on his '90 RS project, so this is not his first project car. I overhauled my first engine when I was 12 with the help of my dad (a '65 Dodge Polysphere 318), so I appreciate the tenacity of a teenage mechanic. A lot of my teenage ideas on cars and hot rods didn't work out and I had to change my plans, and I suspect that Tim will go through that as well. But at the same time the whole process will give Tim a fantastic real life mechanical experience.
My mother, bless her heart, would even let me drag car parts into the house. Later, I once assembled an engine for her car in the family room. It was quite shocking for her friends to see, but she told them it was okay because it was for her car!
Who knows how Tim's '84 Corvette will turn out, but I think we should all cheer him along.
Thomas
P.S. Tim, no matter what you have read about big block C4 conversions, it is much more of a messy project than you might think. There really is no good way to get a decent header design into a street big block C4. Many street conversions end up using the heavy and restrictive cast iron manifolds. You may, or may not know, that big blocks are very sensitive to exhaust flow: a proper header is often worth 70 hp vs. the cast iron manifolds on a performance big block. There are other issues, but I'll hold back and wait to see if you start a thread on a big block installation.
Thanks Thomas I appreciate the kind words, I was talking to my friend about the car at work a couple hours ago, and we wont be doing the big block swap into the vette hes going to find something else to put it in. As for me I think Ive decided on putting the engine back to its original state I'm going to try and keep it as original as possible, my friend told me everything in the car is numbers matching which is awesome and its a complete car nothings missing except the timing chain and cover that I know of. I think I want to keep the crossfire, for now, and see if I can add a few more ponies to it. I would like to get about 250+hp if its possible I think its rated at 205hp if im not mistaken. So what are my options in getting that horse and what things in the crossfire should I change. Try to keep it budget friendly. thanks tim
p.s. I will try to see the car today and if I do I will take a ton of pics so y'all can see what I'm working with. from what I understand its a small project like my camaro, it needs engine, exhaust, and paint work and I need to figure out something to do with the seats there a little messed up. I'll keep you posted sometime tonight.
Old Apr 10, 2010 | 10:15 AM
TLS_Addict's Avatar
TLS_Addict
A friend of mine put abig block in his 80s IROC........took him a LONG time and it took a lot of yelling, beer drinking, and split knuckles....lol
Old Apr 10, 2010 | 12:00 PM
kangi's Avatar
kangi
Tim, I'm glad to hear that! I can't wait to see some pics.
Old Apr 10, 2010 | 01:38 PM
85vette-84vette
If you are going to switch to a different intake. You could go with a superram or a HSR or a miniram. All excellent choices. I was going to put a superram in my 84 until I bid on an 85 vette for something to do and I won the 85 for $4300 so now I will put the superram on my 85 vette. If you want the proper harness to switch to a superram I have it and you could buy it if you want.
Old Apr 10, 2010 | 02:14 PM
sk8rferlife
cool thanks, but what exactly is a superram or HSR or miniram i've heard of people talk about them on the TGO board but never really looked into it, could someone explain them and how much is it to get a setup and what are the advantages/ disadvantages?
thanks tim
Old Apr 10, 2010 | 02:33 PM
85vette-84vette
superram is a tuned port injection on sterodes. It has loads of torque from the low end to the top end because of the longer runners.
This is my superram I am putting on my 85 vette.
miniram is basically a LT-1 style intake and is easy to install but has little low end torque. you need a higher stall convertor to make it affective.
A HSR is a holley stealth ram, the guy in this thread that goes by the name "qws" has one he can tell you about it and all of these intakes will fit under your hood. There is a shorter HSR made to fit under the 84 to 96 vettes hood.
You just need to modify your existing harness or buy a new one.
Old Apr 10, 2010 | 06:50 PM
qws's Avatar
qws
First ... glad to see your keeping the CFI. You are right 205hp from the factory. Second Ported intake, cold air mod are important to reach your goal of 250hp. thats a very realistic goal. With those mods listed above puts me about 260-270 at the wheels.
Old Apr 10, 2010 | 09:41 PM
sk8rferlife
cool so with just those mods I'll be putting around $1500 into the car, not bad, I'm taking a look at the car tomorrow morning after work and I'll show you guys what I'll be working with. I'm hoping the engine will crank and isn't seized up my friend didn't have it long enough to check, and I might be getting a set of superflows with the car, (cheap flowmaster knock off), we'll see. But it might be a little while before I start the resto thread but I'm hoping to be able to start by summers end, if I'm lucky. I'll keep you guys posted thanks for the help.
thanks tim
p.s. - does anyone have a link to show that cold air mod and how to do it, same with porting the intake? also can I do all these mods by myself or should a shop do it, I'd rather I did it myself.
Old Apr 10, 2010 | 10:30 PM
qws's Avatar
qws
For porting go to post #6- RodJ, second link
cold air mod is easy.
Just above radiator shroud you will see a oval hole that goes up into the hood. That hole feeds air through the hood to the CFI. Now look down at the radiator shroud. No hole there!... make one that matches the hole in the hood and your good. If I can find a pic I'll post it. or someone else will have one.
Old Apr 11, 2010 | 07:52 PM
johnnyboyC4's Avatar
johnnyboyC4
nothing is wrong with it that I know of, I cant start it because theres no timing chain, cover, and who knows what else has been taken off. I do know it needs a rebuild and my friend who has 30+ years of auto expirience suggested I use carb and I wanted to anyways. I figured If i'm rebuilding might as well upgrade and hope to find some way of passing emissions. Plus I don't want to have to use a computer that needs tuning and such like a tpi or something. Could just swith the intake if that does have restriction problems and keep the crossfire?
after I get the car I'll know more about what it needs and I put up a restoration thread to keep everyone posted.
thanks tim
The car's 26 years old. It doesn't need to pass emissions testing. Mine didn't. It saves you money. For $14.50, you can have a safety only inspection done on it! I eventually want to show my car in classic car shows because you don't see them ANYWHERE today. It really turns heads, but I can't trust it just yet on the street because SO MUCH stuff needs to be replaced right now. But I am planning to keep it as original as possible so I'm gonna stick with the TBI unit. Maybe I'll put Lambo doors on it...
Old Apr 11, 2010 | 10:37 PM
  #33
The Green Rocket's Avatar
The Green Rocket
Don't get too comfortable with Texas ans emissions testing. I believe that right now only El Paso is subject to I/M testing standards - but I understand there is movement afoot to expand that to other areas.
Thomas
Old Apr 24, 2010 | 02:26 AM
  #34
sk8rferlife
ok guys sorry it took so long to reply, unfortunatley I wont be getting the vette. Instead he will be trading it for a 77 trans am and droping his big block into that. myself on the other hand will be doing an engine swap and turning my 90 camaro into a street/strip car and when I start that I will post a link to the thread that'll be in another forums so you guys can check out the progress on that.
thanks for everyones help anyways
Old May 26, 2010 | 11:23 AM
  #35
sk8rferlife
Ok guys I'M BACK!!! My friend didn't get rid of the vette instead this weekend or next will be putting in his big block and I'll be getting the crossfire and rebuilding it for my camaro. I will take lots of pics and keep you guys updated as much as possibe, and I'll probally take a video of the first start up.
Until the swap...Tim
