Will not start?
Old Apr 9, 2010 | 04:44 PM
gcpoe10's Avatar
gcpoe10
Default Will not start?
I have a 94 LT-1 vette, Fuel psi is good & spark to the plugs, will not start!! Can any one tell what is going on? Thanks Gary.
Old Apr 9, 2010 | 06:32 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Did it set any codes? Also possible VATS issue.
Old Apr 9, 2010 | 08:18 PM
gcpoe10's Avatar
gcpoe10
No codes, I think your right wish i knew how to bypass that thing/ It was runing yesterday. New plugs compresson was good & good spark to plugs & fule pressure was good? 75k on the clock
Old Apr 9, 2010 | 08:35 PM
jfb's Avatar
jfb
Defective VATS will not allow the starter to crank the engine, so that leaves VATS out. Internal combustion engines require spark, spark at the right time, fuel and air and in the correct ratio and cylinder compression in order to start and run. Use your timing light to see if you have spark at the right time during cranking. Use a fuel pressure gauge to see if you have fuel pressure (35-42 psi) and to see if it holds up for a long time with the ign off. Rapid pressure drop could be due to leaky injectors. Get a noid light (auto parts store), or make one with an LED (light emitting diode) and a series 680 ohm 1/2 watt resistor and connect it across an unplugged injector plug and see if it pulses during cranking. Homemade light must have the correct polarity connection to the injector plug to work. Pull some spark plugs and measure compression. Come back when you have some answers.
Old Apr 9, 2010 | 08:54 PM
gcpoe10's Avatar
gcpoe10
Thanks so much i will get started tomarow. And let you know. Thanks Gary in AZ.
Old Apr 9, 2010 | 09:34 PM
rodj's Avatar
rodj
Originally Posted by jfb
Defective VATS will not allow the starter to crank the engine, so that leaves VATS out. .
VATS takes out the injectors as well so if that component of VATS module faulty ,possible to have crank; no start because no injector pulse
Old Apr 9, 2010 | 09:58 PM
gcpoe10's Avatar
gcpoe10
I will check injector pulse in the morning, Thanks for your help. & will keep you posted.
Old Apr 10, 2010 | 01:06 AM
RRT vette's Avatar
RRT vette
Shoot some starting fluid in the throttle body while someone cranks the engine. If it starts, you have a fuel problem.
Old Apr 10, 2010 | 02:14 AM
gcpoe10's Avatar
gcpoe10
Thanks , I will try that , Hope it starts, I will let you know. Gary in AZ.
Old Apr 10, 2010 | 06:45 PM
gcpoe10's Avatar
gcpoe10
Hey Guys, Pulled my opti off to day when i took off the cap water came out!! Well now i know why it diden't want to start, Do you think i can clean it up and put it back on or replace it?
Old Apr 10, 2010 | 08:49 PM
murray59's Avatar
murray59
Depends. How and when did you get water in the opti?
Old Apr 10, 2010 | 10:31 PM
gcpoe10's Avatar
gcpoe10
Don't know for sure? Just bought this car, But you can see that it boiled over & I'm sure thats when it got wet looks good inside?
Old Apr 10, 2010 | 11:19 PM
surfer92's Avatar
surfer92
Is the engine turning over?
Is it water or coolant in the opti?
If it is coolant, just replace the opti.
Old Apr 10, 2010 | 11:49 PM
gcpoe10's Avatar
gcpoe10
Yes turns over, I'm thinking coolant, I will start looking for a opti. Thanks for your help Gary.
To Will not start?
