Strange vibration
Old Apr 9, 2010 | 08:09 PM
Weav's Vet's Avatar
Weav's Vet
Default Strange vibration
About two weeks ago I changed the rear spindles out on my '96. The spindles are used. About a week ago I noticed this strange vibration from the passengers side rear wheel area. It only happens in 2nd gear under fairly strong throttle and only last a second or so. I've checked for movement in the spindle by moving the tire in the 6/12 3/9 positions and it is tight as a drum. There are new fiber washers on the car, new Spicer U joints all around including the drive shaft. I did remove the half shafts to get better access to the torx bolts for the spindle hub. Is it possible to get the half shafts half out like a drive shaft? In other words should I remove it and rotate it 180*? I have also noticed a kind of roar or hum in the drive train when at cruise speed.
Ideas.....
