Rocker Stud Loosened
Old Apr 10, 2010 | 11:48 AM
77vettejeff's Avatar
77vettejeff
Default Rocker Stud Loosened
I have a 1990 L98, Jasper rebuilt motor with 15000 miles. Today I found one of the rocker studs loosened enough for the rocker to come off the pushrod. I noticed the threads (in the head) for the rocker stud has a helicoil installed. I'm guessing this is not done at the factory, correct?
Old Apr 10, 2010 | 12:29 PM
383vett's Avatar
383vett
I may be wrong, but I thought stock heads came with pressed in studs.
Old Apr 10, 2010 | 01:23 PM
77vettejeff
These are definately screw-in studs. The heads are 113's and are aluminum. I lock-tighted the stud and torqued to 50 ft lbs. Hope it's ok now.
Thanks,
Jeff
To Rocker Stud Loosened
