About 94 computers.
Old Apr 11, 2010 | 11:59 PM
car5car's Avatar
car5car
Default About 94 computers.
Are engine computers all the same? I mean for base models?
Old Apr 12, 2010 | 07:49 AM
corvette95's Avatar
corvette95
lots of variables with used ccm's. You can have yours reflashed at Ken Andersons in Georgia. CCM's rarely go bad by the way. So make double dam* sure thats the problem
Old Apr 12, 2010 | 09:20 AM
car5car's Avatar
car5car
Ecm?
Old Apr 12, 2010 | 10:08 AM
toptechx6's Avatar
toptechx6
Last edited by toptechx6; Apr 12, 2010 at 08:57 PM. Reason: OP changed his original post
Old Apr 12, 2010 | 11:27 AM
boonie c4's Avatar
boonie c4
Originally Posted by car5car
Will used CCM work? Rebuilt one is almost $500, used is 75-200
i would just buy a 94-95 GM "caprice,impala, camaro" compatable computer of Ebay "$50-$100" and send it to PCM4LESS along with the vehicle vin number and have them reflash it and you should be good to go
Old Apr 12, 2010 | 08:34 PM
-=Tom=-'s Avatar
-=Tom=-
If you're talking about the PCM then yes they're the same. Like Boonie mentioned, grab a used one off ebay from any of those model cars and just reflash it using your stock bin file.
I've got a spare one I bought off a fellow forum member here for my 95 and when I got it I flashed it with a dump of my stock bin file and it works great in my car and I use a slightly modified file on the PCM in my car and have swapped between them.
If you really wanted (I'm in Canada), you could send me your original PCM and the used one and I'll dump the data from the original and flash the used one and send them both back to you as long as you cover shipping both ways. I'm sure someone on here would offer to do it for you and they live closer to where you are.
Hope this helps.
Old Apr 12, 2010 | 09:30 PM
car5car's Avatar
car5car
Hope this helps.
You could reprogram PCM? What hardware did you use? Where did you get a cable and program?
Old Apr 12, 2010 | 09:33 PM
car5car's Avatar
car5car
Toptech, thanks, I got it! You are smart!!!!!!!!!!
Old Apr 12, 2010 | 10:06 PM
ZR1 NABE's Avatar
ZR1 NABE
its there a way to adjust your mileage on these PCM's ?
its just a questions.... because I replaced my pcm and the same mileage popped up again.
like I said its just curiousity
Old Apr 12, 2010 | 11:02 PM
pcolt94's Avatar
pcolt94
The mileage is stored in the CCM (not the PCM or ECM). I can be changed with a Tech 1 but you need the correct software module for the interface. There may be scanners that can do that function also but I could not tell you exactly which ones.
Old Apr 13, 2010 | 02:13 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You have a 94 the first year of a learn computer.YOu can down load
LT-1 edit or tuner cats and program it yourself.Yours is a smart computer not dumb like 93 and older.
Old Apr 13, 2010 | 04:57 AM
toptechx6's Avatar
toptechx6
This is true, the only "gotcha" is that the mileage can only be entered in a new or rebuilt CCM within the first 100 miles, after that it becomes locked.
Old Apr 13, 2010 | 09:12 PM
pcolt94's Avatar
pcolt94
Thanks for completing my thought. That is the catch. I knew there was a second part but could not remember the exhaust words so left it out rather than being incorrect.
To About 94 computers.
