C4 in Standing Mile Accel
My origional point was that the current Z06 was NOT more aerodynamic than a C4, and I believe I backed up that point w/data.
Since they are so close, then all else equal, RWHP being the same, of course the two cars should go about the same speed.
"The article" WAS relevant. You can't see the forest for the trees. That engine may be "all aluminum". It may cost $51k and it may rev 7k. None of that matters. What matters is 603hp=208-214mph in that car. I bet that if you think REAL hard, you can figure how to build a cast iron block, 6000 RPM engine that costs less than $50k and still makes 603 CHP. Am I right? Today we have things that weren't easily available when that article was written; GREAT heads for cheap, awesome roller cam choices, tons of intake options, all sorts of header/exhaust/cat options, affordable big cube short blocks, turbo and supercharger technology....on and on. The piece that we can ALL take away from that article was the 603 hp/208-214 mph relationship.
The current ZR1 (same body as the Z06) has 640 CHP and can touch 205 in ideal conditions. 640 horse ZR1=200-205 mph. 603 horse C4= 208+. So yeah, I think if a 440RWHP Z06 can tag 198 then a 440RWHP C4 can too. Or maybe slightly better.
Doesn't matter what material the engine is milled from, or how much it costs.
No go is right. It's all speculation. Only way to verify is to try it. But if a car w/the same hp, same Cd, and bigger frontal area goes xxx speed, it seems to reason that a smaller version of the otherwise similar aero specs should go just as well.
I can see the forest for the trees. I understand your point, and it was tell taken.
I dont know enough about top speed, and what kind of power it takes for a C4 with reach 200 mph, but I would love to try. I am pretty sure I have the powerplant to give it a shot.
I know on the Salt Flats, you need more power to achieve the speed due to the 1) Elevation of the salt flats 2) The heat of the salt flats 3) the salt itself, which kind of sucks your car in like mud and adds to the rolling resistance severely........ all 3 of those are substantial by themselves..... add them together and its my understanding whatever you think you need to reach a speed, add another 50 HP.... and even more.
Thus, when talking about top speed runs, it should be seperated which one they are.
On how much power to go 200 mph, I do not know, but I can share what I do know...... about 10 years ago, a California racer was part of the silver state classic, in his 86 C4 - 383, Superram motor, trick flow heads with a hyd roller comp cam and 355 rwhp, hit 186 mph..... that motor was probably around 425 flywheel...... was a full weight car, but for the racing, taped up all gaps on the front end of the car, I guess that helps a bit. Car was a manual transmission, but I do not remember what tranny it was.....
btw, at the recent Florida 1 mile run the OP has mentioned, a friend of mine in his C6 Z06 hit 174 mph....... he is pretty much stock, I think he has an air box of some sort..... I was impressed... it sounds fast anyway.
I also knew Rick Doria from way back in Southern California years ago, he's a well known road racer in those silver state road-race type events, and a very successful one. In his C4, he was reaching close to 220 mph speeds (210 at least) with only a 525 HP motor..... however, that was a race only car specifically set-up for road racing and I would estimate his race weight in the neighborhood of 2700 lbs... if that.... but I am not sure.
Btw, if you any of you socal people want advise on that type of racing, stop in at "Haus of Pizza" in Costa Mesa and talk to Rick about it.... Rick owns the Pizza restaurant and is there a lot.... or at least used to be. Its a tasty pizza too. He knows as much about top speed C4 racing as anybody considering he was the class record holder and the guy to beat for years.
hope this helps.
http://forums.corvetteforum.com/c4-z...p-date-13.html
My personal opinion based on the data that I've seen is that it would take roughly 450rwhp to do an honest 200mph in a C4, providing for proper gearing and enough road.
I've been past 180 in mine (480rwhp) and at that speed the digital speedo was still increasing by 2 numbers at a time.
I also suspect that the new ZR1 may be capable of more than 205mph
Like you said, it's all about proper gearing...
Good PointHere is a Z06 with a cam and headers going 200+ (road is a closed course). I do not agree with the way he was driving in the beginning, but this is just for a speed example (I think he may curse due to excitement at the end so...)
What are the C6 ZR1 gear ratios?I just did a quick search and found this:
1st-6th = 2.29, 1.61, 1.21, 1.00, 0.81, 0.67
Beach Bum: reading some of the Salt Flat racer trials-excess weight (even added ballast) is welcome for stability (traction?) in many cases. I was amazed as some of the race poundages those things scale in-of course.
Auroro40: thanks for posting a link-I hadn't noticed that in the ZR-1 section-that project is incredible! 220 mph.
I think it is safe to say you won't use 6th on a topspeed run unless you regear the rear axle (4.11, etc) and then you may have issues with driveshaft speed. I calculate that you can hit 212 or so with 5th at ~7200 rpm...I'm sure this is what Car and Driver did with their Lingenfelter SB2 Corvette.
Simple calcs show 200 equals 6800 rpm with my current setup-probably pretty close. Admittedly, I haven't included a variable for tire growth at that speed-surely there is some.
Of course no one has mentioned aligning your power peak with the rpm required to hit the number...in other words if you peak at 6000 and it you need 6800 on the clock...you ain't going to make it unless you still have enough power on the backside of the peak-unlikely.
We haven't talked about that, and I agree that going past the power peak...well, at that speed, I don't think the engine would. Tq is dropping fast, as load (drag) is increasing exponentially. You'd have to gear it to hit hp peak at or darn close to terminal velocity.
Not sure where youi're sourcing your info from, but that is dead wrong. The transmission in the current (and last) Z06 features TWO overdrives; 5th AND 6th....just like the ZF6 in a C4.
Can you change your post to reflect who made the quote ?
thanks
On a seperate note, your stock C6 put down 360 rwhp ? Thats pretty impressive.... technology marches on ! It wasn't too long ago that 360 rwhp was a seriously hopped up stroked motor with a lopey cam..... now they're doing it off the factory floor in the base engines...... times have definitely changed !
At the Salt Flats properly balanced heavy cars have more stability. When I was there in 2006 helping "The Avanti Kid" (mostly I was just there for the fun), he was running ~ 700 lbs of balast. The salt is a unique racing surface: it can be about as hard as concrete, seemingly with the breakaway traction of ice. Another salt Flat oddity: a lot of racers favor an open non-posi differential to help with stability when the driven (power) wheel spins at high speed.
Thomas
