Does engine stall when you check stall speed?
Old Apr 14, 2010 | 05:22 PM
car5car's Avatar
car5car
Default Does engine stall when you check stall speed?
I checked bad Honda transmission and RPM went to exact standard stall speed and then didn't go higher. Engine kept running. Is that what supposed to happen or engine should stop?
Thanks.
I am transmission beginner, repaired 1.5 transmissions so far.
Old Apr 14, 2010 | 07:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
Pics of half trans?
No it wont shut down.
Old Apr 14, 2010 | 07:45 PM
car5car's Avatar
car5car
Pics of half trans?
I only repaired valve body. What is interesting, I repaired Impala valve body according to Honda manual, using 600 sandpaper.
Then I repaired Honda Goldwing starter according to Harley repair manual.
Old Apr 14, 2010 | 09:37 PM
Churchkey's Avatar
Churchkey
Suggest you do not repair Vette with Honda or Harley manual :~).
Old Apr 14, 2010 | 09:41 PM
bomar76's Avatar
bomar76
Please post a picture of the roof of your garage.
Old Apr 14, 2010 | 09:48 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I suggest you don't "attempt" to repair any Harley's either.
Are you sure you know what "stall speed" means?
Old Apr 14, 2010 | 09:50 PM
bomar76's Avatar
bomar76
Add "don't fly any aircraft" to that list too....
Old Apr 15, 2010 | 01:47 AM
car5car's Avatar
car5car
Bomar you have ugliest avatar I ever seen. I hope it not you. It is irritating. Any chance you change it to let us say picture of your Vette?
Old Apr 15, 2010 | 01:52 AM
car5car's Avatar
car5car
My Harley is fine, it runs great, I will paint it after I am done with Vette.
99 FLHTCUI, what do you have?
I don't know what stall speed means, that is why I ask questions about it.
Old Apr 15, 2010 | 10:39 AM
aboatguy's Avatar
aboatguy
Here's a quick and simple read that may answer your stall questions
http://www.competitionplus.com/03_25...confusion.html
Old Apr 15, 2010 | 12:52 PM
azrocketman's Avatar
azrocketman
car5car,
I've noticed that you have a number of posts on parts availability and tool requirements. You would do well to get a FSM (Factory Service Manual) for the specific vehicle you are trying to fix.
Relative to stall speed testing, keep in mind that stall testing generates a lot of heat in the transmission. Repeated stall operation may shorten transmission life.
Steve
To Does engine stall when you check stall speed?
