Half Shafts- Question?
Old Mar 14, 2002 | 05:56 PM
Dan85's Avatar
Dan85
Cruising
Default Half Shafts- Question?
I am in the process of replacing the wheel bearings on my 85 z51. I have the rear assemblies off and was wondering if anyone has any experiance as to the best way (easiest) way to service the u-joints on the half shafts. Is there a way to do this job without messing with the rear end alignment? THANKS.
Old Mar 14, 2002 | 06:23 PM
thedevl's Avatar
thedevl
Default Re: Half Shafts- Question? (Dan85)
What "service are you wanting to do? If the ujoints have more that about 50k on them, you should replace em, I would, and did at about 45k. If you remove the tierod ends, and the bolt at the hub for the camber brace,then the saddle clamps, you can remove the half shafts. When you put them back, should be no change to the alignment as the adjustment locations have not been touched and there is no adjustment to the parts removed.
Flynn :reddevil
Old Mar 14, 2002 | 06:31 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
There is a good post about how much u-joints cost going on right now and should have a link to Scorp's how-to page that should answer all your questions.
Old Mar 15, 2002 | 02:25 AM
Dan85's Avatar
Dan85
Cruising
Default Re: Half Shafts- Question? (Vette92)
Thanks for the replys. That is a great "how to" by Scorp. Better than haynes. Yes I should have said replace instesd of service. The devl said the shafts can be removed by taking the camber brace loose on the knuckle end. I think I will try that first. Thanks again for all the great info.
Old Mar 15, 2002 | 01:58 PM
scorp508's Avatar
scorp508
They can be, but I found removing the other end and pulling down on the camber rod to push the knuckle outwards was easier. Thanks on the how too compliment. :)
Old Mar 15, 2002 | 02:20 PM
thedevl's Avatar
thedevl
Default Re: Half Shafts- Question? (scorp508)
Scorp508:
My logic was not to touch anything adjustable. By removing the camber brace at the knuckle, push it down out of the way, pull the knuckle toward you and the shaft will fall out. Either was works. Just sharing my logic.
Flynn :reddevil
Old Mar 15, 2002 | 02:23 PM
scorp508's Avatar
scorp508
Default Re: Half Shafts- Question? (thedevl)
Makes complete sense, that is why in my version you make those scores to correctly align the car again. :)
Old Mar 15, 2002 | 03:56 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
I do it differently than both of you. I actually remove my rear spring and remove the bracket at the differential end so I do not change any settings. It only take 5-10 minutes to drop the rear spring.
To Half Shafts- Question?
