ported intake
Old Apr 15, 2010 | 10:20 PM
gregs86's Avatar
gregs86
Default ported intake
my question is can a ported stock intake perform as well as a eldebrock tpis ect. if not how close can it flow to the above mentioned
Old Apr 16, 2010 | 07:23 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
what year?
Old Apr 16, 2010 | 01:05 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't believe that there is enough material, regardless of year, to get the flow that an aftermarket base will deliver. If you wleded up the roof, and made a raised runner, you might get close and end up w/a better head entry angle.
Old Apr 16, 2010 | 01:12 PM
cv67's Avatar
cv67
St. Jude Donor '05
You can get them to 1.7 or so but it takes a lot of doing especially if you go all the way through which you really need to make a difference.
Old Apr 16, 2010 | 05:37 PM
black85's Avatar
black85
I can't find it right now, but there is an article where someone tested all different intakes on the tpi. One thing they did was test an extrude honed factory intake base, and it performed ALMOST as well as the TPIS. I think others have ported it by hand, so you should be able to get similar results. I've been thinking about it, because all the base intakes are around $500!
Old Apr 16, 2010 | 05:42 PM
pologreen1's Avatar
pologreen1
I had one that was a GM base, and the guy that bought it had the accel one also, he compared, and they were the same. You can port the after market a little more, but on a stock 350 motor or even bigger, I doubt that tiny bit you would ever feel, might show up on a dyno, but IMO it would really only show on a flow bench which doe not really mean too much when you get to that point.
In short save your money and port like nuts, or buy a used one someone did already.
Old Apr 16, 2010 | 06:02 PM
black85's Avatar
black85
In this article they compared a stock tpi to an extrude honed base with large runners. Not exactly what you are talking about, but fwiw http://www.compcams.com/Community/Ar...?ID=1737510521
Old Apr 16, 2010 | 06:11 PM
cv67's Avatar
cv67
St. Jude Donor '05
It will run at least 300-400 to have a pro do your stock base to that extent probably more. Its a royal pita and extremely time consuming should you go though it too far in where you cant weld it the manifold is junk be careful. Id look for a used aftermarket base and do some cleanup work if you had to.
Old Apr 16, 2010 | 06:13 PM
gregs86's Avatar
gregs86
its a 86e but im building a new motor zz short block 180 afr heads 1.6 roller rockers the thing is i was thinking of buying a polised plenum with slp runners but the intake is stock but supossed to be ported pls it has the 58 throttle body and the plenum is ported but i would hate to have to buy a new intake as well oh i still need a cam leaning towards the 211-219 lpe any opionons
Old Apr 16, 2010 | 06:23 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Originally Posted by gregs86
It's a 86e, but im building a new motor. A zz short block, 180 afr heads, and 1.6 roller rockers. The thing is, I was thinking of buying a polished plenum with slp runners, but the intake is stock and supposed to be ported. It has the 58 mm throttle body and the plenum is ported, but I would hate to have to buy a new intake. Oh, I still need a cam. I'm leaning towards the 211-219 lpe any opinions?
Now isn't that better?
Old Apr 16, 2010 | 07:34 PM
Pwnage1337's Avatar
Pwnage1337
Lol. Grammar corrections have a special place in my heart because of this forum.
Old Apr 16, 2010 | 07:38 PM
gregs86's Avatar
gregs86
would say sorry about the grammer but im not didnt no i would be graded just a poor dumb white boy lol
Old Apr 16, 2010 | 08:30 PM
BADDUCK's Avatar
BADDUCK
I didn't correct his grammar boys. Might want to look that one up. A little punctuation and spelling would be nice. If you get a red line under a word it means something is amiss!
Old Apr 16, 2010 | 08:50 PM
gregs86's Avatar
gregs86
makes me want to try for my ged again if i could git a bit of tooturin...but me passed p.e. with flyin colors and i type with to fingers alsotook me 20 minutes just to type this but thats checkin my spellintwo
lol lol
Old Apr 16, 2010 | 09:07 PM
tombrown's Avatar
tombrown
Cruising
Black85, great article - thanks.
To ported intake
