Engine Noise Diagnosis
Old Apr 16, 2010 | 02:04 AM
ShaneL's Avatar
ShaneL
Default [Resolved] Engine Noise Diagnosis
Recently my daily driver 1996 CE with 155K miles on it started making a rather loud and annoying noise that seems to be coming from the vicinity of cylinders 5 and 7 on the drivers side of the engine. It seems to have progressively gotten worse and I've stopped driving the car for the time being.
The noise seems to get quieter as the engine warms up, and seems to have a frequency of 1/2 engine speed. Here is a link to an audio clip I made; the mic was placed beside the exhaust manifold and the engine started cold, idle was about 1000rpm and the last section of the audio was with the engine revved to 1500rpm.
I haven't done much troubleshooting with the engine yet, and cutting fuel to the cylinders in question does not seem to change anything.
What should I do next? I was going to go get a mechanics stethoscope to try to pinpoint the sound a bit better, Autozone was a no-go so I'll try O'reilly tomorrow. I have the FSM (surprisingly brief on engine noise unless there is another section buried somewhere) to help me along and I'd rather get my hands dirty than pay big bucks for someone to do it for me.
Any thoughts would be greatly appreciated,
Thanks!
Old Apr 16, 2010 | 03:35 AM
ddahlgren's Avatar
ddahlgren
Just pull the valve cover off and look for broken parts. Sounds like broken valve train to me.. rocker spring pushrod something sounds wrong in there.
Old Apr 16, 2010 | 06:11 AM
car5car's Avatar
car5car
I am pretty sure you have a problem I fixed 2 days ago.
It is cracked exhaust manifold.
When I used my stethoscope with stick I couldn't hear that sound. I could hear it w/o stick, not touching engine. Sound is not clear because it is under shield.
My manifold had 2 cracks.
Old Apr 16, 2010 | 06:27 AM
ddahlgren's Avatar
ddahlgren
Either way I would sure want to know which one and not drive it until I knew for sure. Sort of pick what you want to take apart first I would go from whatever you think is easiest first..LOL.. I hate working on exhaust so I picked valve cover.
Old Apr 16, 2010 | 05:31 PM
ShaneL's Avatar
ShaneL
Got a stethoscope today, and can hear the noise when I put it on various places under the valve cover. It gets quiet fairly quickly when the engine warms up so I'm having a hard time pinpointing it, but it seems to be nearest the exhaust valve rocker stud on cylinder #7; those studs seem to be fairly noisy places either way though so I'm not too sure of it.
On the exhaust idea, I got rid of the cast iron bricks a few years ago in favor of long tubes, but welds do tend to crack occasionally so I can't dismiss that idea.
If I knew for sure it would fix my problem, I'd be tempted to do a cam swap and replace lifters, pushrods, rockers, and springs, and have the heads checked at a shop.
Thanks for the input!
Old Apr 16, 2010 | 06:45 PM
car5car's Avatar
car5car
Go to mechanic and pay for diagnosis.
Old Apr 16, 2010 | 07:21 PM
383vett's Avatar
383vett
I thought all C4s came with short runner stainless headers, at least my 84 did. I'm not sure I would throw a bigger cam into a motor that has the miles that yours does. Maybe a freshenup and new cam would be a better idea.
ShaneL's Avatar
ShaneL
Found the problem... Split-Lock header bolts had come loose so I re-torqued all of them, noise is now gone.
Thanks for the winning suggestion, car5car
To Engine Noise Diagnosis
