i forgot to count the threads on my leaf springs when i did my u joints. Any body know how many should be exposed from the bottom of the nut? any help appreciated.
If stock I seem to remember they are castle nuts and there should be a hole in the bolt that the cotter pin goes through to secure the nut. That determines where the nut goes.
Originally Posted by jmgtp
I just did mine. I threaded them up just far enough so I could get the cotter pin through the castle nut.
For the factory rear bolts and nuts.
But if you have aftermarket lowering bolts, you probably won't have a hole in them for a cotter pin.
Those use a nylock nut that is self locking. In that case just run them up so you have about 1/4" of bolt showing.
