Introducing my 383 Stroker!
Old Apr 23, 2010 | 06:24 PM
  #61
dclafleur's Avatar
dclafleur
Originally Posted by 89Corvette6spdFX3
Well, you will need to break in the motor... an easy drive to Wichita might be better.
I think my ol' beat up 350 could make it to Wichita!
Old Apr 24, 2010 | 11:45 AM
  #62
tequilaboy's Avatar
tequilaboy
What do you think about a MAF upgrade while you're at it?
Originally Posted by GREGGPENN
Stock GM ECM (with chip)
Originally Posted by Red Dragon On DL
Very nice work!! What are you going to run for a management system?
Old Apr 24, 2010 | 12:02 PM
  #63
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Well, the MAF is definitely a restrictrion point -- really THE restriction point. I was planning on descreening (at least the back), but hadn't gotten to that decision yet.
I know TPIS sells ends that are supposed to help, but I'm doubtful on that one. If a used Granatelli is posted, I might consider that. (BTW, I know there's one posted but it's for an LT1)
The intake tubes will probably flow 260ish. With two tubes sucking at a time, 520ish (cfm) seems like the demand the TB will "see". So, a 600cfm TB seems sufficient.
I'd think about a MAF upgrade MUCH harder if I swap to the HSR (with the 58mm Accel TB I have to go with it).
Old Apr 24, 2010 | 12:12 PM
  #64
tequilaboy's Avatar
tequilaboy
I was thinking about the Blowerworks MAF, which could also be done with a larger housing if desired.
http://blowerworks.net/
You could even polish it.
The trouble with a larger housing is what to do about a supporting airbox, ducting and throttle body, since the factory airbox neck is the next choke point. This is easier to handle on f-bodies.
I would like to see somebody try a C6 or Z06 style aftermarket airbox, but so far no takers, since its somewhat cost prohibitive.
If you want to go this route, I can help make it work.
Old Apr 24, 2010 | 03:10 PM
  #65
GREGGPENN's Avatar
GREGGPENN
Thanks for the link and offer. It looks like a great alternative to the Granatelli's. But, I'm not convinced I need it (yet). If I do, I'll definitely give it serious consideration.
As this point, I just want to complete installation, figure out how to tune it, and hear/see/feel it run again. It's been down a LONG time!
Old Apr 24, 2010 | 03:56 PM
  #66
88BlackZ-51's Avatar
88BlackZ-51
Greg.
You prob wont need it. With your combo, I cant see it peaking much past 5000 rpm's if any with the long runners. Is that about what you think?
It's not just the MAF with our cars, its the angle of the rad, and the ****ty airbox.
Sorry, Just read your earlier thread where you said 5400 rpm's. I could see that more with a SR, but not your intake.
But I am just talking out loud, and I really don't know. My stock L-98 peaked around 4300 on the dyno.
Old Apr 24, 2010 | 08:34 PM
  #67
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
Awesome Build! I can't wait to see a dyno chart of the torque curve!
Old Apr 24, 2010 | 11:18 PM
  #68
BadSS's Avatar
BadSS
Gregg,, that's one of the best looking engines I've ever seen,,, and I've seen a lot of them. It'll look right at home in your car as well.
Old Apr 24, 2010 | 11:24 PM
  #69
BadSS's Avatar
BadSS
No,, really? Get out of here. I would have never guessed you talk about things you have no clue about!! LOL Seriously,, have you ever run a siamesed runner fully ported TPI or SuperRam on an engine with heads remotely similar in size and flow to these AFR heads?
Old Apr 24, 2010 | 11:59 PM
  #70
GREGGPENN's Avatar
GREGGPENN
Thanks...Especially for all the help and knowledge you passed on. I know you're goals are normally focused more on the timeslip (and your vote is for the HSR intake), but the element of character is definitely part of my equation.
That said, here are a couple of (camera-phone) pics that I'm sure you'll appreciate. (You can be sure it'll end up polished if I swap to it later this summer!)
Old Apr 25, 2010 | 12:02 AM
  #71
ch@0s's Avatar
ch@0s
I like the look of the TPI but I think this is your combo
Old Apr 25, 2010 | 12:08 AM
  #72
Steve85's Avatar
Steve85
Cruise-In V Veteran
Seriously, all this talk of MAF restriction, I don't get it. We have been here long enough to see what Corkvette, 85vet, and ski_dwn_it have done through early MAF sensors.
For those that have come after (and those that have forgotten): 85vet runs a 383 to high tens, ski_dwn_it, before going to DFI, ran in the 10's with a 406 and 434 and Corky has run as low as 10.0x through an 85 MAF with a 434. Not to mention high 10's through the same MAF using a 406 and 355. Those numbers mean HP, you can't make that HP unless you are getting air in the engine.
No long tube runner 383 is going to try and suck more air than a single plane equipped 434 with 227cc heads.
Given the examples, I would say you don't need an aftermarket MAF sensor.
Old Apr 25, 2010 | 12:35 AM
  #73
GREGGPENN's Avatar
GREGGPENN
I was just wondering if he'd even read the "Ten Times the Torque" comparison (that's gone around here for years -- and I directly linked for him) before deciding what a siamesed intake can/can't do,,,or whether he just wasn't impressed with my porting work.
FWIW, if I don't hit 5300-5400rpms for my hp peak, it will be because I didn't port it well enough. So, now you know.
At the time I ported/polished the intake, I considered following my work with Ehoning. But I ended up deciding that money could be better spent elsewhere. That's about the time I figured out how to finance a 383 (vs doing a H/C upgrade to my stock bottom-end) came about.
Better choice?
Old Apr 25, 2010 | 12:41 AM
  #74
GREGGPENN's Avatar
GREGGPENN
Agreed (with stipulations). But, no need for this discussion here/now.
Old Apr 25, 2010 | 12:57 AM
  #75
GREGGPENN's Avatar
GREGGPENN
How would YOU know? Have you ever run an HSR?!?!?!
Seriously, looks were DEFINITELY part of the decision. So was mpg, how I drive (gear selection), where I drive (mostly city streets), if environmental conditions could force my EGR/AIR to be reinstalled), etc....
If trap-times were my primary goal, a polished HSR would be sittin' there in post #1. There is NO doubt the HSR would be faster when tagged from 0-120mph. But, I don't drive above 75-80mph. Intakes, gearing, and street driving complicate the issue further. There are other threads where I discussed my reasons at length if you're interested in reading/discussing it.
Plus,,,maybe I just wanna punch it and see if I can generate enough torque for the front tires will come off the ground! (just kidding there)
Torque,,,that reminds me. What should I choose for a personalize license plate. (Pics of the car are in my profile, if you haven't seen it.) "Torque" comes to mind as a choice! But it's probably taken.
Old Apr 25, 2010 | 01:15 AM
  #76
ch@0s's Avatar
ch@0s
Did you forget?
first combo
second combo
[IMG][/IMG]
Old Apr 25, 2010 | 01:27 AM
  #77
GREGGPENN's Avatar
GREGGPENN
Did you forget?
No, not for a minute. That was a joke, son! Did you notice the word "seriously" after my comment!?
Guys who've tried both SLP/HSR setups are my idols!
To Introducing my 383 Stroker!
Old Apr 25, 2010 | 01:41 AM
  #78
ch@0s's Avatar
ch@0s
:o sorry, I think you should try then both and do a dyno comparison.
My mods pale in comparison. I noticed a considerable difference you should benefit more with the HSR IMHO.
Old Apr 25, 2010 | 04:03 AM
  #79
88BlackZ-51
No I have not.
Old Apr 25, 2010 | 12:04 PM
  #80
dclafleur's Avatar
dclafleur
If you don't mind, what kind of numbers did you put down with that combo?
