Introducing my 383 Stroker!
Old Apr 17, 2010 | 11:14 PM
  #41
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
In addition to getting the motor home today, my helper and I got this accomplished.
Old Apr 18, 2010 | 11:20 AM
  #42
STL94LT1's Avatar
STL94LT1
Looks like a piece of art!! I would have to leave it in my living room for a while just to enjoy the site.
Old Apr 18, 2010 | 12:07 PM
  #43
Calderone's Avatar
Calderone
congrats gregg !!!
Its a piece of art !!!
Old Apr 18, 2010 | 01:44 PM
  #44
GREGGPENN's Avatar
GREGGPENN
At just over 400lbs at 2500 rpm it should be a lot of fun on the street, should pull well in about any gear without having to wind it up.
As an added bonus, torque should stay above 400ft/lbs until the 5800rpm range (because of the modified intake). My smaller cam will add more responsiveness to sub-2500 rpm range. So, the usable torque range for city rpms will be quite wide.
Still....If it turns out to be too peaky (having too much mid-range torque), I'm saving an HSR as a backup plan. And, I haven't forgotten how to polish/port.
FWIW: Peak crankshaft torque should be ~500ft/lbs and last from 3400-4800rpms. You should see how the torque curve compares to a stock L98!
Old Apr 18, 2010 | 02:31 PM
  #45
rklessdriver's Avatar
rklessdriver
Your new engine looks really good Gregg.
I'm sure your going to be pleased with how it runs.
Will
Old Apr 18, 2010 | 05:38 PM
  #46
GREGGPENN's Avatar
GREGGPENN
Will
Thanks Will. I appreciate some of the suggestions you provided. I'm really excited to see how the Wiseco's run!
Old Apr 18, 2010 | 05:50 PM
  #47
Weav's Vet's Avatar
Weav's Vet
Very nice! I know you're gonna enjoying driving and showing that one off.
Old Apr 18, 2010 | 08:16 PM
  #48
GTA8500's Avatar
GTA8500
is it in yet!! i want to see how it looks in the vette!! it going to be "EYE CANDY"
Old Apr 18, 2010 | 09:12 PM
  #49
ch@0s's Avatar
ch@0s
All I can say is WOW!
Old Apr 18, 2010 | 09:40 PM
  #50
dirtcheap74's Avatar
dirtcheap74
Its a work of art.........
Old Apr 22, 2010 | 01:00 AM
  #51
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
I think you need to make a trip down to Oklahoma after you get it in. Lafleur and I want a ride!
Old Apr 22, 2010 | 01:26 AM
  #52
GREGGPENN's Avatar
GREGGPENN
I'll meet ya half way! How's Ottawa sound?
Old Apr 22, 2010 | 04:24 AM
  #53
USAsOnlyWay's Avatar
USAsOnlyWay
That looks great! Looking forward to hearing how it runs. I've run a similar combo and you will make outrageous torque from 1800-5200 or so. That will be a very fun motor. I wish you luck on your install...hopefully it goes smoothly and everything still looks pretty in the car too!
Old Apr 22, 2010 | 12:13 PM
  #54
89Corvette6spdFX3
Well, you will need to break in the motor... an easy drive to Wichita might be better.
Old Apr 22, 2010 | 12:16 PM
  #55
tpi 421 vette's Avatar
tpi 421 vette
Looks really nice I think the combo you put together should work well. It will be a torque monster.
Old Apr 22, 2010 | 11:56 PM
  #56
grantar2's Avatar
grantar2
Realize you did a lot of work yourself. Any estimate of cost + time to build out the motor?
Old Apr 23, 2010 | 01:40 AM
  #57
GREGGPENN's Avatar
GREGGPENN
Tons and tons of time (communicating here, with builders, and best-priced parts-shopping) No way to tell on that one.
80-hrs to port/polish the intake
Cost? Well, I'm afraid to REALLY add up all the parts! (Though I guessed (low) in another thread in General). Everything is new except: Dizzy, Edelbrock base, plenum, lifter retainers/tray, fuel rails, and oil pan. It's unbelievable how the little things add up!
I took about 6mos to research, shop, and buy short-block parts. (That doesn't include the heads/intake(s). Builder took 4-6wks (on/off) to machine/assemble longblock.
Ultimately, buying a rotating kit, bearings, and block (if necessary) would be much simpler -- saving LOTS of time. Part of my problem was I bought the heads and had them angle milled to 56cc for reuse on my OEM 350. Milling was a waste of money after I chose to do the 383. Plus, it made shopping for pistons a bit more complicated. (There ended up being only one "right piston for me and I didn't find it right away. But I found a set on Fleabay and regained milling costs since noone else bid. I got $600 pistons for 1/2 price -- 20cc 4032 Wisco 5.7" rod forged pistons.)
To Introducing my 383 Stroker!
Old Apr 23, 2010 | 11:51 AM
  #58
Red Dragon On DL's Avatar
Red Dragon On DL
Cruising
Very nice work!! What are you going to run for a management system?
Old Apr 23, 2010 | 04:35 PM
  #59
GREGGPENN's Avatar
GREGGPENN
Stock GM ECM (with chip)
Old Apr 23, 2010 | 04:38 PM
  #60
Red Dragon On DL
Cruising
Thats is what my 383 is running, stock ecu & hypertech chip was set up by the previous owner. Not sure if it can handle that looking for more of a custom made chip for this set up.
1991 - C4 - 6SP -383
Full Roller/TPIS Intake Man/58mm BBK/Hooker Comps/30lb Inj/TF 23 Heads/Griffin Rad/Oil Cooler/Mystery Cam
2000 - S4 - 6SP - Daily
