1985
Old Apr 16, 2010 | 07:39 PM
thornton310's Avatar
thornton310
Default 1985
Can anyone tell me where the ECU is located on a 1985, thanks.
Old Apr 16, 2010 | 08:25 PM
cumbercr's Avatar
cumbercr
It is located under the dash on the passenger side. You need to remove the trim on the bottom to see it. I found it was easiest to remove the seat to get room to get under there. There are two 10MM? nuts that hold it in place. Pretty easy once you get in there.
Old Apr 16, 2010 | 08:51 PM
thornton310
thanks
To 1985
