1986 - A/C defrost valve
Old Apr 19, 2010 | 06:34 AM
Pres712's Avatar
Pres712
Default 1986 - A/C defrost valve
I figured out that the defrost valve must be stuck and I see by my book that it is located on the left side of the center vent. Can I access it by taking off the center console or do I have to take off the drivers side console also?
Old Apr 19, 2010 | 07:51 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You have to take off instrument panel, to remove center panel.
http://members.shaw.ca/agent86/Dash%...%20Removal.pdf
Old Apr 19, 2010 | 02:28 PM
Pres712's Avatar
Pres712
I have everything off, including the digital instrument cluster. I still can't see or find the vacuum control for the defrost. It looks to me like the entire dash board (top pad) has to come off? Otherwise the entire dashboard has to come off? I had my wife (small hands) feel around back there, but nothing. Any suggestions?
Old Apr 19, 2010 | 04:09 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
I think I would take the top dash pad off. Then you can see from above. You'll be able to move the defrost door from there.
Most likely you have a vacuum leak, not a valve problem. That's the problem I had. The vac lines under the controls fed some mice.
Patched them up and everything works great
Old Apr 19, 2010 | 07:26 PM
AGENT 86's Avatar
AGENT 86
I'm pretty sure I could see the actuator, when I had my dash pad off.
To 1986 - A/C defrost valve
