Hesitation when accelerating
Old Mar 15, 2002 | 06:03 AM
akisana's Avatar
akisana
Default Hesitation when accelerating
Hello everyone
I'm having a problem with my '89 corvette coupe...when I'm in "drive" gear, I get a rough idle and also when I'm accelerating, I get a lot of hesitation. eventually the speed will pick-up, but the hesitation is very nagging. I want to take it to a shop, but before I start paying I would like to get an imput as to what the problem might be. thankx in advance, everyone.
Old Mar 15, 2002 | 09:36 AM
wegozoom's Avatar
wegozoom
Default Re: Hesitation when accelerating (akisana)
Have ya changed the air filter (real easy), loosed the snorkel from the TB and sprayed a pile of TB cleaner(most difficult is spraying with one hand whilst wiggling throttle plate with the other), ran a bottle or two of fuel injector cleaner through it (grandma can do it), or changed the plugs and O2 sensor(I do this as a set).
You might have done all of this but you gave no information as to what you tried.
Mike
Old Mar 15, 2002 | 10:44 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Hesitation when accelerating (wegozoom)
:yesnod: Tell us what you've done so far.
Old Mar 15, 2002 | 11:17 AM
NUckINg FuTS's Avatar
NUckINg FuTS
First thing I would look at is the ignition; cap, rotor, plug wires, and plugs.
Old Mar 15, 2002 | 11:23 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Hesitation when accelerating (NUckINg FuTS)
You'd be amazed at what a simple tune up will do for ya!
BTW, :seeya Welcome to the forum!
Old Mar 17, 2002 | 05:49 PM
akisana's Avatar
akisana
Default Re: Hesitation when accelerating (War Machine)
Hello again to everyone who responded to my question. I tried cleaning the trottle body, but the rough idle and hesitation when acceleration still remains. I had the computer read and the only problem or suggestion that I got, was that the MAP line or port could be clogged. I don't know what this is, but I have the manual for my car, so I'll try to find out about it. If anyone have more info on what this is, please help...thankx in advance
To Hesitation when accelerating
