What Springs, Etc?
Old Apr 21, 2010 | 01:44 PM
MK 82's Avatar
MK 82
Default What Springs, Etc?
I have the engine out of my LT4 and plan to do a cam swap. I am looking at max lift of 0.536 and think that may max out the stock LT4 springs.
What is a good aftermarket spring to use?
Locks?
Retainers?
I plan to keep the stock valves and go with Comp Pro Mag lifters.
Any ideas. Lloyd Elliot suggested Crane Double Springs 99893 and Comp 10 deg retainers and locks. Do I really need the 10 deg retainers?
Old Apr 21, 2010 | 02:10 PM
engle1147's Avatar
engle1147
Part #'s for use with 99893 springs.http://http://cranecams.com/pdf/Page633-634.pdf
If your interested I've got a brand set of new "LT4 hot cam" valve springs, locks & retainers I bought off of CF member Firevette in the F/S section about a year ago. I never installed them and they are still in the same box they were shipped in. I went with a different way with my setup so they are just sitting on the shelf. Give'em to you cheap if you want them. I believe they are good to .540 if I remember right.
Old Apr 21, 2010 | 02:35 PM
MK 82's Avatar
MK 82
I am pretty sure they are the same springs, etc that came on the LT4. 540 doesn't give me enough wiggle room.
Old Apr 21, 2010 | 04:37 PM
engle1147's Avatar
engle1147
I need a bit more lift myself.
Tip - wait to order your roller rockers until you have choosen/ gotten your spring set and your sure of the OD of your new springs. OD of a spring will often vary with higher spring tension ratings.
Old Apr 21, 2010 | 08:14 PM
MK 82's Avatar
MK 82
Unless someone talks me out of it I will go with the Crane 99893 doubles. Crane 99630 10 deg titanium retainers and locks.
I was looking at the new Crane Ultra Pro Mags but they don't list an application for 7/16 for the LTX. I may have to use 3/8. I have to buy new rocker studs eitherway.
Old Apr 21, 2010 | 11:04 PM
96GS#007's Avatar
96GS#007
I'd go with beehive springs from Comp. Lighter weight which results in better valve control. CompCams can set you up with the right part numbers.
To What Springs, Etc?
