max Compression on 93 Octane
Old Apr 22, 2010 | 07:25 PM
MK 82's Avatar
MK 82
Default max Compression on 93 Octane
While I have my LT4 out I am considering milling the heads to increase the CR slightly. Yes, I will mill the intake too.
How high can I go on 93 octane?
Old Apr 22, 2010 | 07:30 PM
Caboboy's Avatar
Caboboy
There's not enough info here, it's all about quench and your dynamic CR; not static CR
Old Apr 22, 2010 | 08:13 PM
cv67's Avatar
cv67
St. Jude Donor '05
503 cam?
Old Apr 22, 2010 | 08:22 PM
MK 82's Avatar
MK 82
503 cam?
Yes. Let's keep this simple.How much can I mill off the LT4 heads?
Old Apr 22, 2010 | 11:09 PM
SpedRacr93's Avatar
SpedRacr93
Given the valve timing on that cam and the duration, you could increase your compression slightly without any problems.
If it were me, I wouldn't bother. If you're still running the factory bottom end you're at 10.8:1. Lets say some time down the road you end up decking the block and need to mill the heads, then you would really be pusing it for streetability and would be forced to change heads.
Bottom line is you do have room to increase compression and still run on pump gas without any issues. You could bump it around 11.25 without worrying most likely, but you're not going to gain a whole lot.
Old Apr 22, 2010 | 11:33 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
The top guys running for 1/4 mile times are willing to go into the lower 11's (static),,,possibly higher. For the ones I ran the DCR for, they were usually in the 8.2-8.5 range -- which is consider fine. (Escecially if you keep your running temps in the 180-210 range).
I'm thinking you'll only gain about 1-1.5hp/cc.
BTW: Mass engine builders don't recommend going over 10.25:1"ish" -- unless you have a great build and good reason -- because they don't want to assume the extra risk.
Old Apr 22, 2010 | 11:40 PM
dogfish246's Avatar
dogfish246
Whats the difference in compression ratios that are static and regular compression ratios? What is usually listed from the manufacturer?
Old Apr 23, 2010 | 12:52 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Static Compression is what is given by manufacturers and can be calculated by measuring the actual components (ie head chambers, quench, bore, etc). This is the "theoretical" compression ratio.
The Dynamic Compression is what the "Actual" compression is. If you think about it, the piston starts to move up in the compression stroke before the intake valve is all the way closed. Technically you are not building compression until it closes all the way. This form of compression takes into account the valve timing on the camshaft and that is why a cam is used to calculate compression. This number is the one that matters when worrying about knock. Typically one does not want to go above 8.75 MAX DCR.
Hope this helps!
To max Compression on 93 Octane
