86 Rear Suspension problem.
I saw that the strut inner mount had moved from impact and moved it back. I can't see any visual damage. When I put tires and wheels on rear and measure the difference between R and L tilt the L is 3" and the R is 2". I put a level on side of tire while on the rack and measured from level to bottom of tires. Where should I look for damage? Seems like the only thing adjusting the tilt would be the strut and it looks straight.
