just started missing and "studdering"
Old Mar 15, 2002 | 03:09 PM
dave85c4's Avatar
dave85c4
Default just started missing and "studdering"
Came back from lunch and the 85 started missing under load. Idle is jumping around 570 to ~800. At steady speed it not to bad, but you can feel and hear it thru the exhaust that somethings not right. Just had a Major tune up 2k ago. I know its not hte cat. I just put on a set of new mufflers but theyseem to be flowing ok. You can feel the skip in the exhaust. Any ideas before I start playing the change game? :confused:
Old Mar 15, 2002 | 06:13 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: just started missing and "studdering" (dave85c4)
1st thing I would check would be timing.
Old Mar 15, 2002 | 08:10 PM
White Lightning's Avatar
White Lightning
Default Re: just started missing and "studdering" (NUckINg FuTS)
Had a similar problem with my 89. Turned out to be the ECM was bad. One other thing it did (other than the missing and stuttering) was the mileage and average mpg readouts went squirrelly.
Maybe you got some bad gasoline or your fuel filter is going. I'd fix those two before doing anything else. Change your fuel filter and then run some Chevron Techron fuel system cleaner through your system.
-WL
Old Mar 16, 2002 | 12:22 AM
dave85c4's Avatar
dave85c4
Found the problem, checked timing and cap. It was the number 2 plug. Back to running great. Thanks for the tips. :cheers:
Old Mar 16, 2002 | 12:49 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Could you clarify a little on what was wrong with #2 plug????
To just started missing and "studdering"
