does the button on the automatic shifter knob do anything?
Old Apr 24, 2010 | 09:22 AM
slickfx3's Avatar
slickfx3
Default does the button on the automatic shifter **** do anything?
I see the pictures of the shifter alone and the threads hold the ****; but is there a rod that releases any lockouts?
Old Apr 24, 2010 | 09:42 AM
LTxDave's Avatar
LTxDave
Yes, you have to press the button to move the shifter from park.
Old Apr 24, 2010 | 09:43 AM
Aurora40's Avatar
Aurora40
I'm quite sure it is like 100% of GM automatics with the button. If you don't press the button, you can shift back and forth between N-D. And you can shift up from 1-2-3-D, but not back down.
If you press the button, you can do anything.
Old Apr 24, 2010 | 10:07 AM
engle1147's Avatar
engle1147
100%
Old Apr 24, 2010 | 10:46 AM
CalvinMD's Avatar
CalvinMD
If like the other famous **** of mention ..its to keep your hand from slipping off the end
Old Apr 24, 2010 | 11:01 AM
markKlein's Avatar
markKlein
The **** is held in place with a clip, I'm not sure what threads you are speaking of.
Old Apr 24, 2010 | 11:19 AM
ch@0s's Avatar
ch@0s
Old Apr 24, 2010 | 02:22 PM
slickfx3's Avatar
slickfx3
I thought the **** was screwed on ( I am coming from a ZF6) like the manual trans, I guess it just slides on, where is the rod that releases the lockout? I have a B and M proratchet that has to go bye bye.....
Old Apr 24, 2010 | 05:36 PM
LTxDave's Avatar
LTxDave
The button activates a rod that runs down the center of the shaft holding the shifter ****. You can pry/pull the button off and the clip that holds it on remains on the shifter. To remove the shifter ****, there is an external snap ring under the button that will need to be removed. I cannot remember if the **** screws off or just slides off when the snap ring is removed, but once the snap ring is removed its a simple task.
Old Apr 24, 2010 | 05:58 PM
slickfx3's Avatar
slickfx3
thanks that is the answer i was looking for , I just bought a shifter from feebay, with no ****,
now i know you can't drive the car without the ****....
Old Apr 24, 2010 | 06:39 PM
car5car's Avatar
car5car
You have to be very gentle with that ****! Wait a second, are you talking about a car?
Old Apr 24, 2010 | 06:59 PM
LTxDave's Avatar
LTxDave
You can drive the car without the ****. I drove mine for several days without the **** while reworking my interior. Its easier if you put the button back on, but it can be done either way.
Old Apr 24, 2010 | 07:31 PM
slickfx3's Avatar
slickfx3
so... you can press the lever with a finger or something?
Old Apr 24, 2010 | 07:34 PM
car5car's Avatar
car5car
Finger yes, don't know about something, never tried!
Old Apr 25, 2010 | 10:33 AM
markKlein's Avatar
markKlein
You can, but you might want to wear a glove, that rod is pretty sharp.
To does the button on the automatic shifter knob do anything?
