These might work. The muffler guy down the street who does good work says he can piece together some standard quiet turbos with LT1 tips, but I was going to inquire to see if he would be willing to try these on my car when I replace my borla clone drone specials.
So how does that valve work, automatically under acceleration and closed on cruising speeds?
It's just pressure sensitive. They have two models with a different spring tension. One for smaller engines under 4 liters and larger 8 cylinder ones.
I fear it may still drone at some engine loads and exhaust volumes...or maybe not.
My last mistsubishi car had a flapper valve in the exhaust. quiet enough inside the car..although people did report that it sounded loud for a stock car. I'm interested to try it on a C4.
I've been looking at it for few minutes and it looks that way. I hope it is stainless steel, if it is not once condensation hits that mechanism its over.
My interest is definately peaked. I'd like to find out the price for the mufflers only. Looks like parts numbers 17690 and 17689. The instruction picture looks like LT1 style tips and it's bare metal. I think I'll get the local guy to check the price. Does anyone know of an on line dealer for dynomax?
I would like to hear it as well.I am more interested in it for my BB Dodge.I won't be removing the Corsa anytime soon.
Kind of like the C6 exhaust.Tame until you hit a certain rpm and then full flow and banshee wail.
What part number are you using to order them? In the install instructions they show 17690 and 17689 for each muffler. When I phoned my local Midas muffler shop the girl looked up the number and said $420 each! That can't be right.
I emailed the tech line and was told there is no direct replacement with a tip, only a universal muffler that you customize into your system. Also when you look at the cutaway it is a straight through muffler, not chambered, and only 1/2 a muffler at that because the flapper portion takes up 1/2 the muffler. I suspect the sound under throttle will be loud and won't have a very nice "note".
It doesn't look that revolutionary. Something like the C6 exhaust has a complete muffler path on one side, and a straight pipe on the other with a valve. When the valve is closed, all the exhaust goes through the complete muffler. And when open, it almost all goes straight out. And of course the valve is not operated by backpressure.
This is only 1/2 a muffler, and a valve that is always open some. So the exhaust always travels the same path regardless. It also seems to ensure there is always backpressure greater than the spring pressure, which is not like a straight-through system at all.
Part number for my application was 17956 cost was $99 per muffler
Ordered them from Jegs
Mufflers were installed and I wish I had better news to report. They did not work for my application.
The 383 motor combined with the cam is causing the valve inside the muffler to open and close very frequently. The sound is no where near ideal (sounds like two spoons clanging together).
It may work much better for stock cars, however, anyone with a higher performance motor may suffer from the same problem I did.
Have since welded the valves in the open position; it is loud but haven't had a chance to test drive for drone.
Oh man you should email the company and tell them about your experience. Maybe they will do something for you, like replace the muffler with another one...
I didnt even think about the lope of a cam causing a problem... Hmmm!
