Best Plugs??
Old Mar 15, 2002 | 06:11 PM
Hi-psi's Avatar
Hi-psi
Default Best Plugs??
What are the best plugs for a mostly stock car?
A friend recommended NGK TR5's?
Old Mar 15, 2002 | 06:36 PM
Rob90's Avatar
Rob90
Default Re: Best Plugs?? (Hi-psi)
NGK TR5's are great plugs. Ive had good luck with rapidfires also
Old Mar 15, 2002 | 06:43 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Best Plugs?? (Rob90)
AC are the best for your car. Yep. :yesnod:
Old Mar 15, 2002 | 06:54 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Best Plugs?? (blk90rdstr)
I personally use the NGK's in my LT-1.
Old Mar 15, 2002 | 07:03 PM
Lone Ranger's Avatar
Lone Ranger
I tried NGK TR55 pure copper's but didn't have so much luck. Car idled rougher than before. On advice of two local Corvette wrenches, I pulled the NGK's and put in a new set of the original equipment AC Delco 41-906's. Smoothed out the idle and it runs good. I have also heard that the AC Delco Rapidfire's are good, the Rapidfire #3 being the one that cross references to the stock original equipment plugs.
To Best Plugs??
