Steering Wheel Removal ?
Old Mar 15, 2002 | 06:37 PM
dans86's Avatar
dans86
Default Steering Wheel Removal ?
I busted the Column Lock Pin on my 86. Will a Universal Wheel Puller work or do you need something special... Thanks
Old Mar 15, 2002 | 06:40 PM
JonM's Avatar
JonM
Default Re: Steering Wheel Removal ? (dans86)
Go to Auto Zone...they have one they will let you borrow
Old Mar 16, 2002 | 03:48 AM
Frizlefrak's Avatar
Frizlefrak
Universal will work, just be careful not to strip the threads inside the telescopic shaft like a certain moron I know (it wasn't one of my better days). Make sure the round fitting is on the end of the puller shaft, or it will bugger the threads in the tele shaft something fierce. You will also need to tool to compress the spring in the lock plate in order to reinstall it.
To Steering Wheel Removal ?
