Headers?
Old Apr 25, 2010 | 11:39 PM
hershell973's Avatar
hershell973
Navigator
Default Headers?
Does anyone have any opinions on headers for a stock 95. My biggest fear is breaking a bolt off in the head while trying to remove the stock exhaust manifolds. Has anyone experienced this and is it worth the risk?
Old Apr 25, 2010 | 11:46 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If you start running into trouble, use heat/cold cycles on the bolt, and shock (hammer).
I think the general consensus is that headers aren't worth much on a stock LT1.
Old Apr 26, 2010 | 01:44 AM
tpi 421 vette's Avatar
tpi 421 vette
I agree with Tom. The more power you make the more headers help you. A bone stock engine might pick up 10 hp. But if you are going to do a bunch of mods, and get as deep as a head and cam swap, then headers really become worth the money.
Old Apr 26, 2010 | 11:05 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Can't do long tubes in Cali either. Not sure about other states.
Old Apr 26, 2010 | 12:14 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Had my stock manifolds off several times before I put on the long tubes.
Did not have any stuck exhaust bolts. Did break one of the studs for the exhaust connect when I pulled them for the last time.
They are not torqued very much.
Good Luck!
Old Apr 26, 2010 | 12:28 PM
1995 vette's Avatar
1995 vette
You might check this it was very good for me.
http://forums.corvetteforum.com/c4-t...post1573873207
To Headers?
