http://www.internetracerssupply.com usually has a reasonable price. Speed Demon Motorsports which is a supporting vendor might be able to get you a slightly better price. The digital 6 is one of those things that is fairly constant from vendor to vendor, usually about $270 or so.
I'm in the market for one unless I can find the right adapter connectors for an Accel 300 ignition I have. I see MSD's on eBay pretty regularly. Just have to bid at the right time. Here's a couple going on right now. Summit carries the proper adapter plug in harnesses. http://cgi.ebay.com/ebaymotors/ws/eB...tem=1812853581
it will work with stock coil................i have just fried one first one didnt work to begin with and the second just took a dump for some reason havent found out why yet. think it is becasue of the distance where i have it mounted
:smash:
Can anyone tell me why one should go with a digital 6 vs. 6AL? I mean, if it's a $100.00 more, it should give you something above and beyond the 6AL right?
On the Accel 300+ Ignition, you must run a seperate ground lead from the case to a good ground on the frame, or you will continue to fry units. I know, I fried mine before I asked them :rolleyes:
Mine was seperately grounded to the frame all by its lonesome. Only thing i can think of is its too far from the engine but i went up in guage size when i added the extra wire like i was supposed to or it just overheated. :cry
cprgmr-
The Digital 6 has a lot more features than the 6AL. Check it out at http://www.msdignition.com One of the features I want is the single stage timing retard for use with nitrous. :seeya
