mild cam
Old Apr 30, 2010 | 08:25 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by WW7
AFR has all the specs you want...WW.
http://www.airflowresearch.com/index.php?cPath=24_29
This site may not list the heads mentioned. If they are AFR heads SOLD by TPiS, then yes. More likely, you have the TPiS-ported AFR heads which has a cooperative effort where AFR provided the blanks and TPiS ran their own CNC-porting. (Not sure they're even in the TPiS catalog anymore.)
If they are the heads I think, you could find specs with a search. A couple of sets have been sold. I remember they had SMALL chambers -- something like 54cc. Seems like they were about 185cc with flow numbers similar to AFR's current 180 Eliminator.
Whether AFR or TPIS-AFR heads, the LPE219 cam is likely to be a good choice -- but again,,,it's the spicy/flavor thing,,,which intake you'll run,,,where you want power,,,etc...
Most people decide on cam AFTER all other parts are selected (though they have an overall use/theme in mind for the build.
