Has anyone used the new style slave cyl. on their vert??
The bleeder screws on both are in different locations,wondering if
i will run into clearance problems. New style being 91-96. All clutch
master cyl. are the same. My model year is $50more than the new style.
Hopefully someone has it!!!!!
Matt
I replaced the old style slave in my '90 with the new style. I didn't have any clearance problems. Infact there may be more room as the bleeder screw doesn't point sideways into the trans. tunnel!
The inlet port on the slave is in slightly different positions on the old and new style slaves. I opted to get the same year hose as the slave. I didn't try using the old hose with the new slave so I don't know if it will fit.
New style slave on top, old stlyle on bottom:
Ohh, braided steel :cool:
I also replaced the clutch master cylinder. I figured that both the master and slave cylinders were the same age. If one failed, the other may not be far behind.
