Wow! Dosen't this look like fun!!!
Old 05-02-2010, 04:50 PM
My1st
My1st's Avatar
Default Wow! Dosen't this look like fun!!!
Tracing bad wiring and heater core change.
Used the pipe you see on myself for getting into this.
Had to have one of these to do this job.
Old 05-02-2010, 05:22 PM
powerpigz-51
powerpigz-51's Avatar
Thats exactly what my car looks like right now!
Old 05-02-2010, 09:42 PM
cgantner5150
cgantner5150's Avatar
Me too, me too. The only difference is that you have carpet and door panels, and console sides. My digital dash is sitting in place though. One step at a time....
Old 05-02-2010, 11:36 PM
Whitecloud
Whitecloud's Avatar
I wouldn't even know where to begin. Best of luck to all of you.
Old 05-03-2010, 06:38 AM
CorvetteMike2024
Corvette Junkie
Support Corvetteforum!
CorvetteMike2024's Avatar
Received 2,033 Likes on 842 Posts
Keep digging. I dont see the heater core yet.
Old 05-03-2010, 07:10 AM
joesgulfstream
joesgulfstream's Avatar
Its there Mike, Its like that game " Where's a what's that kid's name" I just had one of those senior moments can't think of that kid's name. Help me out Mike.
Old 05-03-2010, 07:22 AM
My1st
My1st's Avatar
Heater core is done or as done as it gets. Didn’t have to remove anything more to get at it. Never was able to put the cover on the way it came off. There’s a small gap (1/16”) in the upper right corner where it would not no matter what I did fit the way it was. Not sure if part of the core is in the way or what?
Old 05-03-2010, 07:28 AM
My1st
My1st's Avatar
Hey Mike, do you know what the upper group of wires just below the dash pad in you picture are for? the ones just above the big cluster. I think there are six wires in there and they go into the doors? but not sure what there for. These are the wires that are fried on my car.
Old 05-05-2010, 04:53 PM
j-wireman
j-wireman's Avatar
It's Waldo, from "Where's Waldo?"
Just tryin' to help.
Old 05-05-2010, 04:59 PM
joesgulfstream
THATS IT Thanks, now I can sleep tonight
Old 05-05-2010, 07:42 PM
bill mcdonald
bill mcdonald's Avatar
Originally Posted by gaguy
What do you do with hammer and pipe?
If your not using these tools, your doing it wrong.
Old 05-06-2010, 09:48 AM
CaminoSS
CaminoSS's Avatar
You can make anythign fit with a big enough hammer. But get some duct tape just in case you need to doctor the part up after you are done making it fit!
Old 05-06-2010, 10:24 AM
ch@0s
ch@0s's Avatar
Where is waldo?
Old 05-06-2010, 07:03 PM
My1st
My1st's Avatar
In order to gain access to all of the heater system (and the burnt wires I have), I decided to remove the dash completely. Do the three rivets shown in the picture that are directly above the steering column need to be drilled out?
Old 05-06-2010, 10:16 PM
kenv
kenv's Avatar
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Are the paper towels there for the frustration tears??
Old 05-06-2010, 10:56 PM
AGENT 86
AGENT 86's Avatar
You might find you answers here >>
http://members.shaw.ca/agent86/Dash%...%20Removal.pdf
Did you find out the cause of no injector pulses, on the drivers side ??
Old 05-06-2010, 11:57 PM
Steve85
Steve85's Avatar
Cruise-In V Veteran
Here is my list of tools from my heater core job a few years ago:
(Had a picture of it all on the hood (pre re-paint) but villagephotos sucks)
GIN & CAMELBACK- Fill the camelback with gin and strap it to your back, you'll be under the dash, no time to waste reaching for your drink.
1/4in SOCKETS- Have the whole rack, just make sure it's all 7mm sockets so you have at least one left over when you're done.
EXTENSIONS- You'll need exactly the length they don't make, and a different one for each fastener.
ELECTRIC DRIVERS AND BATTERIES- Have them all, make sure they are all charged, anything less than 4 batteries, go shopping.
GIRL SCOUT COOKIES- A DEFINITE, I recommend Thin Mints(put'em in the freezer) and two boxes of Samoas.
SPOTLIGHT- So you can see into the abyss you'll be working in. An ordinary drop light is not sufficient.
HAMMER- Your going to need to bang the crap out of something from time to time The old heater core makes a fine target
SHOVEL- Why the hell not, it can't make the job any worse.
EARPLUGS- These are for the women and children. Many people have been known to create a mix of words that would make a **** star blush. :bb
BRICKWALL-
CORVETTE FORUM-
Anyway, it just takes time and patience. the reward awaits you
To Wow! Dosen't this look like fun!!!
Old 05-07-2010, 07:24 AM
My1st
My1st's Avatar
Agent 86, yes to the pulse problem, turned out to be the vats. I had mentioned the two wires with pellet between them held together with a clamp. I put a new ignition cylinder and key in it and it cured the problem. Someone had put a non vats cylinder in it thus no pellet in the key I got with the car.
Old 05-07-2010, 12:53 PM
94vettelover2
94vettelover2's Avatar
Whats up keith?Looks like your nailing that wiring hopefully not with the hammerWas the heater core leaking?I don't think the rivets have to be drilled out but am not sure.If they do I have a rivet gun you can borrow.Make sure you check the heater core for leaks before you put everything back together.
Old 05-07-2010, 06:28 PM
My1st
My1st's Avatar
Hey Jeremy, the core wasn’t leaking but as long as I had the dash torn apart to work on the wiring I decided to replace it fear that it may have been clogged. It looked like it needed to be replaced once I got it out so I’m glad I did. I won’t have to worry about doing that job again for a long time. I also checked it before putting it back together. After looking at those rivets probably don’t have to come out. Besides I really think the wires that are fried were speaker wires so I’ll probably just leave them alone and get everything back together so I can enjoy it.
Quick Reply: Wow! Dosen't this look like fun!!!
