1986 Clock/Display Question
Old May 3, 2010 | 05:10 PM
1986coupe's Avatar
1986coupe
Default 1986 Clock/Display Question
I have a 1986 with a Bose stereo. When I turn the car off the display is turned off (not sure if it is supposed to stay on but it sometimes does) When I turn the radio back on it goes to 1:00 and comes on at am and doesn't remember what I have programed.
Should the display remain on in clock mode when the car is off?
What would be causing the above?
Thanks,
Bill
Old May 3, 2010 | 05:53 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Thanks,
Bill
sounds like it's wired wrong. When the key is off, there is no display.
Is this a new problem?
Old May 3, 2010 | 06:06 PM
1986coupe's Avatar
1986coupe
Not new problem...just one that has annoyed me enough to do something about it.
Just now was checking it out. Had the key in the ignition and on. Turned the bose radio off and the clock stayed on...but didn't change...continued to show 1:01 for several minutes.
Sometimes it will stay on and other times will go off. Sometimes only a few lights on the display remain on. Had swapped radios and will do the same thing.
Old May 3, 2010 | 07:26 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If your courtesy lights are working, than maybe someone has wired the clock power to a switched source. Clock and memory are powered by the CTSY/CLK fuse, which is always live.
Old May 4, 2010 | 12:22 AM
jfb's Avatar
jfb
The clock integrated circuit is drain bamaged. Also another circuit in the radio that looks at the on off switch and the headlight switch to determine if the radio dial lights should be on is also drain bamaged.
To 1986 Clock/Display Question
