Code 23
Old May 3, 2010 | 11:33 PM
Marv02's Avatar
Marv02
Default Code 23
I checked out my trouble codes and number 23 come up.
It saids it's a Air Temp Sender I purchased a new one and swaped it out.
But I still get service engine soon light what do I do now HELP.
And it has a ruf Idel.
I installed new type 3 Bosch Injectors from (FIC) checked for vacuum leaks replaced most of the old vacuum hoses out with new ones.
It's a 1986 all stock auto.
Old May 3, 2010 | 11:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
There are 2 connectors between main harness and MAT sensor, are you sure both are connected ?
http://members.shaw.ca/corvette86/Code%2023.pdf
Old May 4, 2010 | 12:07 AM
Marv02's Avatar
Marv02
Default 2nd connector
Thanks where is the 2nd connctor located at ???.
Old May 4, 2010 | 08:53 AM
AGENT 86's Avatar
AGENT 86
One at MAT sensor and one near distributor. Follow the wires back from sensor, you will find it.
To Code 23
