Solar Load Sensor Short
Old May 6, 2010 | 12:21 PM
Jamesnns's Avatar
Jamesnns
here's the beginning
Lenses cut, 8.75 curve, gry 75% solid
Trayed
Blocked and ready to cut to size.
More to follow.
Old May 6, 2010 | 02:06 PM
edwardpayne's Avatar
edwardpayne
Trayed
More to follow.
Amazing! Looking good!
I didn't get the opportunity to check the sensor today. The weather was dark and cloudy and I didn't have a flash light near by. Will try it later and cover it up!
Old May 6, 2010 | 02:11 PM
Jamesnns's Avatar
Jamesnns
Rough cutting
Cut
Rough cut done, there are four.
Cut to 33 mm
Need to drop to 24mm and then cut to fit from there, adjust 3 remaining -0.05mm each for pick fit.
Old May 7, 2010 | 08:05 PM
Jamesnns's Avatar
Jamesnns
Didn't get them done today
early next week.
Old May 10, 2010 | 09:35 AM
edwardpayne
early next week.
It's ok!
No problem, can't wait to see them, looking great on the pics.
My alternator died on me in this weekend and I haven't been able to drive anything since that.
Thanks again!
Old May 10, 2010 | 01:45 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Where did you get the part>?
For her Honda? I went to www.hondapartsonline.net and paid about $25 bones for hers (shipping including).
Old May 17, 2010 | 03:40 AM
edwardpayne
Got a new alternator in the car and tried to hold my sun glasses over the sensor. It seems to fix the error code just to put the glasses over it and I think your lenses will do the work when they arrive
Old May 17, 2010 | 08:25 AM
Jamesnns's Avatar
Jamesnns
Great...........
I'll finish then up and get them to you asap.
edit
Ummmm...
I'm having a problem sizing the lens cover.
Since mine has that black "nipple" cover, I can't size the lens to fit. The black nipple sticks up too much.
Can you reach in and feel if the white "nipple" is reccessed below top of the opening?
My black "nipple" comes even with the top off the dash...hence the problem.
Ahhhh dude....I just did the easiest fix for this...took 2 minutes.
Check your PM.
I'll have to remove my sensor altogether to get it sized.
Old May 17, 2010 | 12:35 PM
Jamesnns's Avatar
Jamesnns
OK.....
I got the skinny from Vette2vette.
Vette2Vette Corvette Salvage
1109 N. Bloomington St.
Streator, IL. 61364
Telephone:
1-815-673-6200 (USA)
He's got your part $25.00, plus he said he'd charge acutal shipping.
He takes CC's.
I can arrange it, I'll pay him and have it shipped, and you pay me Via Paypal or something if you have a problem with out of the country payment??
I cannot find this part anywhere else.
He also stated that he has seen people just take a permanate marker and black it out. The black cap does let some light thru, so completely occluding it won't work.
It's a dual sensor..measures inside car temp and measures light for dash dimming purposes.
I'm having a problem making a cap that will extend over the top of the nipple, at least on mine with the black cap on it. I don't really feel like taking mine apart and possibly breaking it, then I'm buying a new one like you.....lol.
Let me know.
In the meantime, I'll continue to think about a way for me to get this done...possibly using two lenses adhered together with the bottom inside one cut-out in the middle to make room for the nipple?? I'll keep thinking.
At least this is a small issue and not one preventing you from drving your car.
James
Old May 18, 2010 | 02:10 AM
edwardpayne
OK.....
Streator, IL. 61364
Telephone:
He takes CC's.
Let me know.
James
Thats awesome! yes I got Paypal and it wont be any trouble over the border. i would be great if you could handle it and i'll send you the money on Paypal.
So He have the black dome thingie to put over everything?
Old May 18, 2010 | 09:38 AM
Jamesnns's Avatar
Jamesnns
Yes, it's the whole sensor with the black cap with wires and connector. It's all one piece. The black cap looks like it may come off with a cotter pin or something??
Vette2vette won't sell just the cap...
The rear (closest to you) of the vent that has the sensor lifts up, it has three tabs..middle, right, left, and then just pops up and out. The sensor is connected with four wires. Release the tabs on the connector and it comes off easy. They made it easy because the connector wires are long enough to pull the whole unit towards you w/out problems. You're looking at 10 minutes to replace this. I didn't want to take mine out in fear of breaking the wire connector tabs...they get brittle after 20 years.
Anyway, I'll fire you aniother PM about costs etc.
Old May 19, 2010 | 10:19 PM
Jamesnns's Avatar
Jamesnns
Waiting?
Old May 20, 2010 | 12:48 AM
  #33
edwardpayne
Waiting?
Sent you money on Tuesday with PayPal
Old May 20, 2010 | 12:05 PM
  #34
Jamesnns's Avatar
Jamesnns
Part going out tday or tomorrow early am.
Let me know when you get it.
Old May 27, 2010 | 04:09 AM
  #35
edwardpayne
Default [solved]
Ok! The part arrived yesterday and I put it in quite easy!
I just lifted the vent grille, gently, which the sensor sits in.
Could pull everything a little closer to me thanks to the length of the cables.
I separated the cables with at the connector, it was pretty hard to pull apart.
It's only two cables what I can see. Not four.
Question:
Are you sure this sensor both measures light AND temp? It that possible with only two wires or is it a combination of both? I mean, if the sun light generates temperature in the end maybe?
Here is a picture after I mounted the new one. The old one, missing the black cap, is on top
Thank you so much for sending me this sensor!
Old May 27, 2010 | 08:45 AM
  #36
Jamesnns's Avatar
Jamesnns
I'm glad everything worked out. I'm surprized you got the part so fast!!!
The connector end looks different than mine..Your new one is red, mine is very small and gray...ltr year I guess?
I hear you about it being snug, I tried to take mine off and gave up cause I didn't want to break the connector. At least SOMEONE thought about the wire length and made it easier to replace...which is unusal for a vette.
I honestly don't remember how many wires ( 2 or 4 ) mine has, I'll go look this weekend.
I was told by Vette2vette about temp AND sunlight, I was just repeating what they told me, do idk really.
Does this solve your code problem?
let me know if you need any parts in the future if you have problems finding them or getting them shipped to you, I'll be glad to get it/them to you.
James
