Question About Heads
Old May 4, 2010 | 07:43 PM
Nitestalker's Avatar
Nitestalker
Default Question About Heads
My 86 may need heads and I can't find aluminum ones that fit my budget. My question is, can I use the cast iron heads on my 86? Some say yes while others say they won't work due to the EGR setup on it. The car is my DD so I can't have the down time to have them rebuilt. Thanks in advance.
Old May 4, 2010 | 07:47 PM
Pete K's Avatar
Pete K
There are many, many, aluminum and cast iron cylinder head options out there. What is your budget?
Old May 4, 2010 | 07:56 PM
Nitestalker
no more then 500. I was told that I need to run an 86, 87 head only or it would run like crap. I can get a set of cast iron heads with 1.94 and 1.50 from City motor supply but not sure if the will work.
Old May 4, 2010 | 09:00 PM
Aardwolf's Avatar
Aardwolf
Later year 113 heads can be bought, and fixed up for that.
Old May 4, 2010 | 09:04 PM
cv67's Avatar
cv67
St. Jude Donor '05
Google world or EQ heads bet you could come close to a set that will outperform what you have now. Havent looked in awhile though. Try Summit and Jegs see what they may have. Iron heads can still make some power and are cheaper than aluminum. Theres always Patriot they are a low end performance aluminum head check Ebay
Old May 5, 2010 | 12:30 AM
Mark85Vett's Avatar
Mark85Vett
PM sent
To Question About Heads
