solid rollers ... is it so bad
Old May 5, 2010 | 12:28 AM
ZD1's Avatar
ZD1
Default solid rollers ... is it so bad
I am still looking to be "non-chalant" with my motor, but cant seem to find the right can/lifter combo to take advantage of the flow 550 and up in the head, and yet be agressive.
So will pressure fed rollers lifters have good life under 2000 rpm? Will they feed the upper valve train?
Old May 5, 2010 | 08:13 AM
bjankuski's Avatar
bjankuski
A solid roller with pressure fed lifters will be fine below 2000 RPM. A solid roller on the street will work fine.
Old May 5, 2010 | 09:32 AM
cv67's Avatar
cv67
St. Jude Donor '05
Old May 5, 2010 | 04:22 PM
vettef6's Avatar
vettef6
see my sig
very pleased with my combo...
Old May 6, 2010 | 12:41 AM
ZD1's Avatar
ZD1
what brands modl of lifter
Old May 6, 2010 | 03:17 AM
vettef6's Avatar
vettef6
Comp Cams Endure -X CCA-888-16
To solid rollers ... is it so bad
