U Joint Replacement
Old May 10, 2010 | 02:12 PM
94z07fx3's Avatar
94z07fx3
Originally Posted by joshwilson3
Yeah, but you have to use the coated U joints. So technically they aren't available from what I'm being told. The other ones are for steel drive shafts from what I recall.
The difference between the two is the anti-galling coating on the aluminum shaft specific u-joint caps.
I had to use a long flatblade screwdriver to pop out the caps from the yokes anyway so I doubt the anti-galling coating of the original spicers was worth a !@#$! anyway.
YMMV
Some people have put anti-sieze compund on them. I didn't. The recommendataion is not to use any lubricant that would promote a situation that may allow the cap to spin.
Old May 10, 2010 | 02:23 PM
samsonb's Avatar
samsonb
YMMV
I believe the purpose of the coating is to prevent galvanic corrosion. You really wouldn't want that to happen, so I'd play it safe and use the correct coated U Joints. It looks like you can get some from Advance. The Brut Force. But they aren't Spicer.
Old May 10, 2010 | 04:23 PM
Weav's Vet's Avatar
Weav's Vet
How are you going to use coated U joints if you can't buy the good ones any more? I'd rather take my chances with uncoated that use Advance joints.
Old May 10, 2010 | 07:08 PM
SSWEET's Avatar
SSWEET
Is that for the driveshaft or half shaft? If Spicer have the coated U joints for aluminum shafts, then I wonder why it is being said they are discontinued?
Spicer indicated that the SP 5447 X is the proper half shaft U Joints for
aluminum half shafts.............don't know if they are "coated" or not but they are for aluminum...........
Old May 10, 2010 | 08:44 PM
samsonb's Avatar
samsonb
I believe those do have the coating on them. And I believe that is the only Spicer you can get for the Vette with a coating. But it has the grease fitting on it.
So, if you want the coating and NO grease fitting, then you have to go with a different brand if you can't find any NOS coated Spicers.
I'm thinking I'd just go with the coated Brute Forces or Performance Dynamic and not worry about it.
That is if the Brute Forces on my half shafts are still good and what I'm noticing is something else like the OEM ujoints on the driveshaft. If the Brute Forces are wore out on my halfshafts after just 5k-6k miles. Then I think I might look at something different.
Old May 10, 2010 | 09:43 PM
Pearys Ruby's Avatar
Pearys Ruby
I noticed on the web link (http://temp.corvetteforum.net/c4/vad...orpujoint.html) that the calipers were removed from the rotor. (not mentioned in the web link) I assume that removal is necessary? IS THAT TRUE??? Do I need to do any thing special to remove the calipers? Thanks for all the posts. It looks like with all the information I will be attempting to replace the U-joints on my '93. The local Chevrolet dealer charges about a $1,000 to do the job, and I don't think that includes alignment.
Old May 10, 2010 | 10:23 PM
SSWEET's Avatar
SSWEET
The SP 5447-X did not have grease fittings.......
Old May 10, 2010 | 10:30 PM
SSWEET's Avatar
SSWEET
Originally Posted by jhammons01
SSweet.....Just unbolt the spring.......Unbolt the Camber adjustment at the D36 and pull it downward....Unbolt that ball joint and use a rubber mallet to knock it upwards and loose.......Unbolt the straps for the ujoints on the half shafts.
Now the whole hub will move if you push it using your leg....lie under the car and push out ward with your foot. The Half shaft will drop from one end or the other.
Then wriggle/wrestle the half-shaft out.
Easy cheesy, lemon squeezy
Leave the shock and dogbones alone...
Use a bunch of long extensions to reach the inner u-joint straps. You can access them from the top of the half shaft if you remove the rear wheel and look straight inward.
The outer straps are a PIA cause they can only be reached from lying under the car.
Did it like you said...except I unbolted the tie rod end not the ball joint but everything else was like you stated......So easy....even a Caveman could do it.
Old May 15, 2010 | 08:59 AM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by engle1147
The alignment should alter with just the u joint replacement....unless you pull the upper inner camber rod bolt loose/out.
Just double checking this - changing the U-joint WILL alter the alignment unless the bolt is loosened, right?
Not doubting you, just trying to be sure I understand.
Old May 23, 2010 | 08:46 PM
94z07fx3's Avatar
94z07fx3
How do you pull the caps off the ujoint?
After you remove the two 8mm screws that hold the cap straps on the u-joint should slip out of the yoke with a little pressure. The caps will slide off so easily at this point that you run a risk of dropping one and losing its needle bearings so tape them in place or be very careful when it isn't in the yoke. The side that is on the half shaft will need to be pressed out with a u-joint tool or the vise/press + socket method.
Be careful with the pressing as it is not too hard to damage the seal under the caps.
Old May 24, 2010 | 06:54 PM
Weav's Vet's Avatar
Weav's Vet
How do you keep the caps from falling off when you pull the shaft out?
Tape
Old May 24, 2010 | 07:46 PM
samsonb's Avatar
samsonb
Originally Posted by Weav's Vet
Tape
Yeah, I know about the tape. But you gotta pull the shaft to put the tape on. So, I guess you just have to hope the caps don't fall out till you can get the tape on it.
Old May 24, 2010 | 07:50 PM
  #33
Weav's Vet's Avatar
Weav's Vet
If they fall off that easily they're probably shot. If you do decide to keep them just carefully smear a little grease on the needles and that will help them stay on for re assembly. Good luck!
Old May 25, 2010 | 05:11 AM
  #34
Weav's Vet's Avatar
Weav's Vet
Thanks. What grease do you use?
Any general purpose grease will work for that or if you have a grease gun just squirt a little out and use it. As mentioned look at the seals on the caps really close. A while back Spicer went through a bad batch and they were cracked out of the box or very brittle.
Old Jan 30, 2011 | 12:42 PM
  #35
USAFPILOT's Avatar
USAFPILOT
What brand U-joints are you guys using and where are you getting them from?
I'm thinking I need to replace the ones in my halfshaft, as when I hit the gas. It feels like I get kicked in the rear, then when I let off the gas, it feels like someone pulled their foot out of my butt.
And sometimes when I'm almost stopped when I'm braking, I hear a knock from the rear. And sometimes while I'm taking off.
The PO replaced the Ujoints in the drive shaft. He put in Spicer from what I read on them when I was under there last.
my car the same symptoms...i purchased the neapco brute force ujoints...now time to install.
Old Aug 23, 2022 | 12:09 PM
  #36
FirstVettFun's Avatar
FirstVettFun
Default You can remove half-shafts without dismantling the rear suspension
Because the knuckle or Hub won't move outward without taking off some the items listed
Think......Why doesn't your hub pry sideways while you are cornering? 'cause all that "Stuff" is keeping it from moving side to side.
Now, how are you going to pry that knuckle sideways with a screwdriver?? it doesn't pry sideways while creating almost 1G on the skid pad.....Why then wouldn't a screwdriver work??
the Way I listed......only leaves the two dogbones, shock and the sway bar attached.....and they have no "side to side" stabilization.
This is an old thread but I've encountered this subject a lot. And to set the record straight, You Can Remove Your Half-Shafts without removing ANY other suspension struts. When you understand the geometry of the independent design you will learn that the Half-Shafts are the ONLY suspension component that locates the knuckle in the suspension arch of travel. Once you remove the U-joint straps, the knuckle is suspended in space by spindle, camber, toe and spring struts. The knuckle can easily be moved as allowed by the movement/wear of the combined strut bushings. The Spindle, Camber, Toe and Spring 'Struts' Do Not locate the knuckle! The suspension struts only orient the knuckle in relation to chassis setup. To remove the half-shaft, the knuckle only has to be moved enough so that the U-joint cap can clear the cap retaining nodule on the yoke. Then some finessing and rotating of the yokes to line up will allow the half-shaft to drop out.
That said, I usually disconnect the Camber strut to make it easier to reinstall and not drop a u-joint cup. I hate playing pick-up sticks with needle bearings! But those that instruct to needlessly dismantle the rear suspension to remove half-shafts either do not understand the independent design or are just 'parroting' what they've read. If you don't believe me or that the knuckle won't move with the half-shafts disconnected (u-joint straps removed), just try this experiment. Disconnect one side of your half-shafts, pop the car in Neutral, and roll it backwards....And watch your rear tires go full negative camber & toe in!
Bottom Line: The half-shafts don't just propel the car, they are an INTEGRAL part of the suspension.
Old Aug 25, 2022 | 11:27 PM
  #37
colter's Avatar
colter
What all exactly are you removing in order to replace the ujoints in the half shafts? Maybe do a right up?
When I did mine many years ago, the hardest part was getting those spindle bolts off. I ended up buying an impact gun to eventually get them off. I had thought of at the time of replacing those bolts with a different bolt instead of the factory torx head. But I put anti-sieze on those bolts when I reinstalled to hopefully make it easier in the future.
