Help me name this hose?
May 7, 2010 | 12:14 AM
This little hose connects to the throttle body down to the block. What is the name of it and where can I get one? Would NAPA have one or do I need to order it? Thanks a lot. TM
P.S. If I ever get this car back together it will be a miracle. God bless the forum.
May 7, 2010 | 01:02 AM
THROTTLE BODY TO INTAKE HEATER HOSE
You can find the listing for this on Corvette Central's web site. You should be able to get this through most parts stores.....or do the TB by pass and eliminate it all together.
May 7, 2010 | 07:40 AM
Why not bypass the TB. Eliminates a hose, 2 clamps and future leaks.
May 7, 2010 | 09:57 AM
Corvette Central
May 7, 2010 | 10:14 AM
Quote:
Originally Posted by
AGENT 86
What do you mean bypass the throttle body. And thanks everyone for the posts, I'll order one from Corvette Central. Thanks
May 7, 2010 | 10:25 AM
AGENT 86
Unless you live in a cold weather state, bypass the throttle body. It circulates warm water in and out of the throttle body to keep it from icing in cold weather. Also heats up the intake charge in warm weather which will reduce hp. Leave it off if you don't need it. Plug it or connect the 2 hoses, one into and one out of the throttle body.
May 7, 2010 | 10:56 AM
C4 of Year Winner (appearance mods) 2019
383vett
Consider cutting/grinding off the IAC housing's hose nipples after the bypass. Looks much better.
May 7, 2010 | 11:00 AM
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
[QUOTE=383vett;1573998139 Plug it or connect the 2 hoses, one into and one out of the throttle body.[/QUOTE]
Is there any downside to plugging the hose? I just replaced the upper rad hoses, and don't want to just toss them.
May 7, 2010 | 11:27 AM
92ragtop
Yeah, if you drive your Vette in below freezing weather then you can potentially have a problem...
May 7, 2010 | 01:31 PM
From: One day you're a Comet...the next day you're dust... Arkansas
May 7, 2010 | 01:36 PM
BADDUCK
Algernon
May 7, 2010 | 05:05 PM
dogfish246
Not a problem for me. It's a summertime toy only.
May 7, 2010 | 05:55 PM
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
By the looks of it --- I'd call it "Jay"
