Your MSD Opti Status?
Old May 7, 2010 | 11:17 AM
jakers's Avatar
jakers
St. Jude Donor '06
Default Your MSD Opti Status?
Fortunately I do not need a new Opti.
I am curious... so here it goes.
Those who have the MSD opti, how is it working out for you?
How long have you had it MSD'd?
Any problems?
Old May 7, 2010 | 02:42 PM
rklessdriver's Avatar
rklessdriver
Any problems?
My 92 has had it's MSD Opti since late 2007. It's working great so far. I've only put about 5-6,000 miles on it. It does however have too many dyno and tuning pulls to count (all well past 7000RPM).
The 383 LT4 I built for blackharleyman has over 15,000 miles on it now and his MSD Opti is also still going strong. His has been in since July 2008.
The key with the MSD Opti is to loctite the rotor screw and make sure the cap's O-Ring is installed correctly.
Will
Old May 7, 2010 | 06:03 PM
MK 82's Avatar
MK 82
I am putting an MSD cap and rotor on my stock opti. It is not much more than a stock cap and rotor and looks pretty.
My OEM opti has 45,000 on it and is pristine inside so I see no need to change it.
If it ever fails I will go back with an OEM because I think the 95-95 vented model is a very good piece and the price differential is not justified.
Old May 8, 2010 | 07:26 AM
RichS's Avatar
RichS
I put one on last year, mid summer. Been working fine so far. Less than 500 miles on it, but around 50+ 1/4 runs.
Old May 8, 2010 | 09:31 AM
Bill32's Avatar
Bill32
Will
My 92 - MSD is 2007, 10,000 mi. I just pulled it apart because had the w/p off for gasket replacement. The inside looked brand new, even the cap & rotor. The rotor has a very silght bit of carbon that came off with a paper towel.
Will - Round O-Ring? I just got 2 square O-rings from MSD that make the cap install less of a problem.
Old May 8, 2010 | 11:42 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I've had mine for over a year now. I'm having problems with the ICM craping out but I don't know if the opti is the cause.
Old May 8, 2010 | 02:49 PM
airplane50's Avatar
airplane50
Have an MSD opti installed for about a year and 6,000 miles on my 94. No problems or issues. Went with the MSD because the Delco that was installed by a Chevy dealer failed after 7,000 miles. Could not get any warranty help because this dealer went out of business. Also the MSD is vented which the Delco optis for 92-94 are not.
Old May 8, 2010 | 03:10 PM
Weav's Vet's Avatar
Weav's Vet
I have a MSD. Got it from Summit. It's just been on the car a couple of months though. No problems at all so far. I kind of like being able to adjust the timing with the screw that is on them now.
I know they have had their problems with the electrics inside but these things are a work of art to look at. It's a shame you can't see them after they are installed.
To Your MSD Opti Status?
